Falta de espaço na Box Android + armbian
LOG … a verse o @Maddoctor consegue dar com a lebre :hot_face: :hot_face: :hot_face:
root@arm-64:~# curl -sL https://raw.githubusercontent.com/MadDoct/hassio-install        er/master/hassio_s9xxarmbian.sh | bash -sv
#!/usr/bin/env bash
## THIS SCRIPT SHOULD ONLY BE RUN ON A S9xxx BOX RUNNING ARMBIAN ##
set -o errexit  # Exit script when a command exits with non-zero status
set -o errtrace # Exit on error inside any functions or sub-shells
set -o nounset  # Exit script on use of an undefined variable
set -o pipefail # Return exit status of the last command in the pipe that failed
# GLOBALS
readonly HOSTNAME="armhassio"
readonly HA_INSTALLER="https://raw.githubusercontent.com/MadDoct/supervised-inst        aller/master/installer.sh"
readonly REQUIREMENTS=(
  apparmor-utils
  apt-transport-https
  avahi-daemon
  ca-certificates
  curl
  dbus
  jq
  network-manager
  socat
  software-properties-common
# SCRIPT LOGIC
# Ensures the hostname of the Pi is correct.
update_hostname() {
  old_hostname=$(< /etc/hostname)
  if [[ "${old_hostname}" != "${HOSTNAME}" ]]; then
    sed -i "s/${old_hostname}/${HOSTNAME}/g" /etc/hostname
    sed -i "s/${old_hostname}/${HOSTNAME}/g" /etc/hosts
    hostname "${HOSTNAME}"
    echo "Hostname will be changed on next reboot: ${HOSTNAME}"
  fi
# Installs all required software packages and tools
install_requirements() {
  echo "Updating APT packages list..."
  apt-get install software-properties-common
  apt-get update
  echo "Ensure all requirements are installed..."
  apt-get install -y "${REQUIREMENTS[@]}"
# Installs the Docker engine
install_docker() {
  echo "Installing Docker..."
  curl -fsSL https://get.docker.com | sh
# Installs and starts Hass.io
install_hassio() {
  echo "Installing Hass.io..."
  curl -sL "${HA_INSTALLER}" | bash -s -- -m qemuarm-64
# Configure network-manager to disable random MAC-address on Wi-Fi
config_network_manager() {
    echo -e "\n[device]";
    echo "wifi.scan-rand-mac-address=no";
    echo -e "\n[connection]";
    echo "wifi.clone-mac-address=preserve";
  } >> "/etc/NetworkManager/NetworkManager.conf"
# RUN LOGIC
main() {
  # Are we root?
  if [[ $EUID -ne 0 ]]; then
    echo "This script must be run as root."
    echo "Please try again after running:"
    echo "  sudo su"
    exit 1
  fi
  # Install ALL THE THINGS!
  update_hostname
  install_docker
  install_hassio
  # Friendly closing message
  ip_addr=$(hostname -I | cut -d ' ' -f1)
  echo "======================================================================="
  echo "Hass.io is now installing Home Assistant."
  echo "This process may take up to 20 minutes. Please visit:"
  echo "http://${HOSTNAME}.local:8123/ in your browser and wait"
  echo "for Home Assistant to load."
  echo "If the previous URL does not work, please try http://${ip_addr}:8123/"
  exit 0
main
Hostname will be changed on next reboot: armhassio
Reading package lists... Done
Building dependency tree
Reading state information... Done
software-properties-common is already the newest version (0.96.20.2-2).
0 upgraded, 0 newly installed, 0 to remove and 27 not upgraded.
Get:1 http://security.debian.org buster/updates InRelease [65.4 kB]
Get:2 http://httpredir.debian.org/debian buster InRelease [122 kB]
Get:3 http://httpredir.debian.org/debian buster-updates InRelease [51.9 kB]
Get:4 http://httpredir.debian.org/debian buster-backports InRelease [46.7 kB]
Get:6 http://security.debian.org buster/updates/main arm64 Packages [216 kB]
Get:7 http://security.debian.org buster/updates/main armhf Packages [216 kB]
Get:8 http://security.debian.org buster/updates/main Translation-en [120 kB]
Get:9 http://httpredir.debian.org/debian buster/main arm64 Packages [7,736 kB]
Get:5 https://uk.mirrors.fossho.st/armbian/apt buster InRelease [18.3 kB]
Get:10 http://httpredir.debian.org/debian buster-updates/main armhf Packages.diff/Index [3,688 B]
Get:11 http://httpredir.debian.org/debian buster-updates/main arm64 Packages.diff/Index [3,688 B]
Get:12 http://httpredir.debian.org/debian buster-updates/main Translation-en.diff/Index [3,196 B]
Get:13 http://httpredir.debian.org/debian buster-updates/main arm64 Contents (deb).diff/Index [3,196 B]
Get:14 http://httpredir.debian.org/debian buster-updates/main armhf Contents (deb).diff/Index [3,196 B]
Get:15 http://httpredir.debian.org/debian buster-updates/main armhf Packages 2020-06-04-2016.16.pdiff [1,107 B]
Get:16 http://httpredir.debian.org/debian buster-updates/main armhf Packages 2020-06-07-1403.53.pdiff [439 B]
Get:17 http://httpredir.debian.org/debian buster-updates/main armhf Packages 2020-06-13-2000.26.pdiff [552 B]
Get:18 http://httpredir.debian.org/debian buster-updates/main arm64 Packages 2020-06-04-2016.16.pdiff [1,128 B]
Get:19 http://httpredir.debian.org/debian buster-updates/main arm64 Packages 2020-06-07-1403.53.pdiff [439 B]
Get:20 http://httpredir.debian.org/debian buster-updates/main arm64 Packages 2020-06-13-2000.26.pdiff [552 B]
Get:21 http://httpredir.debian.org/debian buster-updates/main Translation-en 2020-06-07-1403.53.pdiff [368 B]
Get:22 http://httpredir.debian.org/debian buster-updates/main Translation-en 2020-06-13-2000.26.pdiff [423 B]
Get:23 http://httpredir.debian.org/debian buster-updates/main arm64 Contents (deb) 2020-06-07-1403.53.pdiff [1,524 B]
Get:24 http://httpredir.debian.org/debian buster-updates/main arm64 Contents (deb) 2020-06-13-2000.26.pdiff [541 B]
Get:25 http://httpredir.debian.org/debian buster-updates/main armhf Contents (deb) 2020-06-07-1403.53.pdiff [1,524 B]
Get:26 https://uk.mirrors.fossho.st/armbian/apt buster/main armhf Packages [191 kB]
Get:27 http://httpredir.debian.org/debian buster-updates/main armhf Contents (deb) 2020-06-13-2000.26.pdiff [541 B]
Get:28 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index [27.8 kB]
Ign:28 http://httpredir.debian.org/debian buster-backports/main armhf Packages.diff/Index
Get:29 http://httpredir.debian.org/debian buster-backports/main arm64 Packages.diff/Index [27.8 kB]
Ign:29 http://httpredir.debian.org/debian buster-backports/main arm64 Packages.diff/Index
Get:30 http://httpredir.debian.org/debian buster-backports/main Translation-en.diff/Index [27.8 kB]
Ign:30 http://httpredir.debian.org/debian buster-backports/main Translation-en.diff/Index
Get:31 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index [27.9 kB]
Ign:31 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb).diff/Index
Get:32 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index [27.9 kB]
Ign:32 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb).diff/Index
Get:33 http://httpredir.debian.org/debian buster-backports/contrib armhf Packages.diff/Index [16.0 kB]
Ign:33 http://httpredir.debian.org/debian buster-backports/contrib armhf Packages.diff/Index
Get:34 http://httpredir.debian.org/debian buster-backports/contrib arm64 Packages.diff/Index [14.5 kB]
Ign:34 http://httpredir.debian.org/debian buster-backports/contrib arm64 Packages.diff/Index
Get:35 http://httpredir.debian.org/debian buster-backports/contrib Translation-en.diff/Index [10.6 kB]
Get:36 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb).diff/Index [14.0 kB]
Get:37 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb).diff/Index [14.5 kB]
Get:38 http://httpredir.debian.org/debian buster-backports/non-free arm64 Packages.diff/Index [8,608 B]
Get:39 http://httpredir.debian.org/debian buster-backports/non-free armhf Packages.diff/Index [11.6 kB]
Ign:39 http://httpredir.debian.org/debian buster-backports/non-free armhf Packages.diff/Index
Get:40 http://httpredir.debian.org/debian buster-backports/non-free Translation-en.diff/Index [10.6 kB]
Get:41 http://httpredir.debian.org/debian buster-backports/non-free armhf Contents (deb).diff/Index [9,592 B]
Get:42 http://httpredir.debian.org/debian buster-backports/non-free arm64 Contents (deb).diff/Index [8,116 B]
Get:43 https://uk.mirrors.fossho.st/armbian/apt buster/main arm64 Packages [205 kB]
Get:44 https://uk.mirrors.fossho.st/armbian/apt buster/main arm64 Contents (deb) [6,461 kB]
Get:45 http://httpredir.debian.org/debian buster-backports/contrib Translation-en 2020-03-09-1419.12.pdiff [352 B]
Get:46 http://httpredir.debian.org/debian buster-backports/contrib Translation-en 2020-03-26-1417.37.pdiff [304 B]
Get:47 http://httpredir.debian.org/debian buster-backports/contrib Translation-en 2020-04-06-0801.17.pdiff [357 B]
Get:48 http://httpredir.debian.org/debian buster-backports/contrib Translation-en 2020-04-14-0801.37.pdiff [687 B]
Get:49 http://httpredir.debian.org/debian buster-backports/contrib Translation-en 2020-04-18-1402.01.pdiff [252 B]
Get:50 http://httpredir.debian.org/debian buster-backports/contrib Translation-en 2020-04-22-1402.51.pdiff [154 B]
Get:51 http://httpredir.debian.org/debian buster-backports/contrib Translation-en 2020-05-19-0807.39.pdiff [604 B]
Get:52 https://uk.mirrors.fossho.st/armbian/apt buster/main armhf Contents (deb) [7,405 kB]
Get:53 http://httpredir.debian.org/debian buster-backports/contrib Translation-en 2020-05-25-2012.07.pdiff [442 B]
Get:54 http://httpredir.debian.org/debian buster-backports/contrib Translation-en 2020-07-22-2003.16.pdiff [617 B]
Get:55 http://httpredir.debian.org/debian buster-backports/contrib Translation-en 2020-08-21-1400.36.pdiff [226 B]
Get:56 http://httpredir.debian.org/debian buster-backports/contrib Translation-en 2020-08-21-2000.29.pdiff [29 B]
Get:57 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-04-06-1401.23.pdiff [216 B]
Get:58 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-04-14-0801.37.pdiff [767 B]
Get:59 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-04-14-1401.32.pdiff [296 B]
Get:60 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-04-18-2003.54.pdiff [493 B]
Get:61 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-04-22-2002.10.pdiff [177 B]
Get:62 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-04-29-0807.09.pdiff [94 B]
Get:63 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-05-19-0807.39.pdiff [476 B]
Get:64 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-05-25-2012.07.pdiff [5,542 B]
Get:65 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-06-11-0203.42.pdiff [287 B]
Get:66 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-07-23-0211.37.pdiff [404 B]
Get:67 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-07-28-1408.27.pdiff [124 B]
Get:68 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-08-21-2000.29.pdiff [284 B]
Get:69 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-08-23-0800.35.pdiff [372 B]
Get:70 http://httpredir.debian.org/debian buster-backports/contrib arm64 Contents (deb) 2020-08-26-2000.52.pdiff [378 B]
Get:71 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb) 2020-04-06-1401.23.pdiff [217 B]
Get:72 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb) 2020-04-14-0801.37.pdiff [769 B]
Get:73 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb) 2020-04-14-1401.32.pdiff [295 B]
Get:74 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb) 2020-04-18-2003.54.pdiff [494 B]
Get:75 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb) 2020-04-22-2002.10.pdiff [179 B]
Get:76 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb) 2020-04-29-0807.09.pdiff [96 B]
Get:77 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb) 2020-05-19-0807.39.pdiff [475 B]
Get:78 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb) 2020-05-25-2012.07.pdiff [5,542 B]
Get:79 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb) 2020-06-11-0203.42.pdiff [289 B]
Get:80 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb) 2020-07-23-0813.21.pdiff [408 B]
Get:81 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb) 2020-07-28-1408.27.pdiff [124 B]
Get:82 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb) 2020-08-21-2000.29.pdiff [285 B]
Get:83 http://httpredir.debian.org/debian buster-backports/contrib armhf Contents (deb) 2020-08-26-2000.52.pdiff [378 B]
Get:84 http://httpredir.debian.org/debian buster-backports/non-free arm64 Packages 2020-03-03-1417.05.pdiff [553 B]
Get:85 http://httpredir.debian.org/debian buster-backports/non-free arm64 Packages 2020-04-03-1401.42.pdiff [255 B]
Get:86 http://httpredir.debian.org/debian buster-backports/non-free arm64 Packages 2020-04-18-1402.01.pdiff [379 B]
Get:87 http://httpredir.debian.org/debian buster-backports/non-free arm64 Packages 2020-05-15-1402.01.pdiff [882 B]
Get:88 http://httpredir.debian.org/debian buster-backports/non-free arm64 Packages 2020-06-15-0800.22.pdiff [442 B]
Get:89 http://httpredir.debian.org/debian buster-backports/non-free arm64 Packages 2020-06-15-1412.06.pdiff [280 B]
Get:90 http://httpredir.debian.org/debian buster-backports/non-free arm64 Packages 2020-07-24-1413.42.pdiff [879 B]
Get:91 http://httpredir.debian.org/debian buster-backports/non-free arm64 Packages 2020-08-21-1400.36.pdiff [2,484 B]
Get:92 http://httpredir.debian.org/debian buster-backports/non-free Translation-en 2020-03-03-1417.05.pdiff [6,390 B]
Get:93 http://httpredir.debian.org/debian buster-backports/non-free Translation-en 2020-03-04-0235.22.pdiff [431 B]
Get:94 http://httpredir.debian.org/debian buster-backports/non-free Translation-en 2020-03-09-1419.12.pdiff [4,463 B]
Get:95 http://httpredir.debian.org/debian buster-backports/non-free Translation-en 2020-03-09-2014.19.pdiff [1,069 B]
Get:96 http://httpredir.debian.org/debian buster-backports/non-free Translation-en 2020-04-17-2006.16.pdiff [482 B]
Get:97 http://httpredir.debian.org/debian buster-backports/non-free Translation-en 2020-06-15-0800.22.pdiff [1,061 B]
Get:98 http://httpredir.debian.org/debian buster-backports/non-free Translation-en 2020-07-01-0810.32.pdiff [359 B]
Get:99 http://httpredir.debian.org/debian buster-backports/non-free Translation-en 2020-07-05-2004.24.pdiff [382 B]
Get:100 http://httpredir.debian.org/debian buster-backports/non-free Translation-en 2020-07-06-0801.46.pdiff [408 B]
Get:101 http://httpredir.debian.org/debian buster-backports/non-free Translation-en 2020-08-21-1400.36.pdiff [3,318 B]
Get:102 http://httpredir.debian.org/debian buster-backports/non-free armhf Contents (deb) 2020-03-03-1417.05.pdiff [15.7 kB]
Get:103 http://httpredir.debian.org/debian buster-backports/non-free armhf Contents (deb) 2020-04-03-1401.42.pdiff [334 B]
Get:104 http://httpredir.debian.org/debian buster-backports/non-free armhf Contents (deb) 2020-04-17-2006.16.pdiff [26 B]
Get:105 http://httpredir.debian.org/debian buster-backports/non-free armhf Contents (deb) 2020-05-15-1402.01.pdiff [115 B]
Get:106 http://httpredir.debian.org/debian buster-backports/non-free armhf Contents (deb) 2020-06-15-0800.22.pdiff [268 B]
Get:107 http://httpredir.debian.org/debian buster-backports/non-free armhf Contents (deb) 2020-06-15-1412.06.pdiff [2,786 B]
Get:108 http://httpredir.debian.org/debian buster-backports/non-free armhf Contents (deb) 2020-07-24-1413.42.pdiff [174 B]
Get:109 http://httpredir.debian.org/debian buster-backports/non-free armhf Contents (deb) 2020-08-21-1400.36.pdiff [2,258 B]
Get:110 http://httpredir.debian.org/debian buster-backports/non-free arm64 Contents (deb) 2020-03-03-1417.05.pdiff [15.6 kB]
Get:111 http://httpredir.debian.org/debian buster-backports/non-free arm64 Contents (deb) 2020-04-03-1401.42.pdiff [332 B]
Get:112 http://httpredir.debian.org/debian buster-backports/non-free arm64 Contents (deb) 2020-05-15-1402.01.pdiff [116 B]
Get:113 http://httpredir.debian.org/debian buster-backports/non-free arm64 Contents (deb) 2020-06-15-0800.22.pdiff [268 B]
Get:114 http://httpredir.debian.org/debian buster-backports/non-free arm64 Contents (deb) 2020-06-15-1412.06.pdiff [2,761 B]
Get:115 http://httpredir.debian.org/debian buster-backports/non-free arm64 Contents (deb) 2020-07-24-1413.42.pdiff [174 B]
Get:116 http://httpredir.debian.org/debian buster-backports/non-free arm64 Contents (deb) 2020-08-21-1400.36.pdiff [2,261 B]
Get:117 http://httpredir.debian.org/debian buster/main armhf Packages [7,698 kB]
Get:118 http://httpredir.debian.org/debian buster/main Translation-en [5,968 kB]
Get:119 http://httpredir.debian.org/debian buster/main arm64 Contents (deb) [36.5 MB]
Get:120 http://httpredir.debian.org/debian buster/main armhf Contents (deb) [36.4 MB]
Get:121 http://httpredir.debian.org/debian buster/contrib arm64 Packages [38.7 kB]
Get:122 http://httpredir.debian.org/debian buster/contrib armhf Packages [40.4 kB]
Get:123 http://httpredir.debian.org/debian buster/contrib Translation-en [44.5 kB]
Get:124 http://httpredir.debian.org/debian buster/contrib armhf Contents (deb) [85.0 kB]
Get:125 http://httpredir.debian.org/debian buster/contrib arm64 Contents (deb) [84.2 kB]
Get:126 http://httpredir.debian.org/debian buster/non-free arm64 Packages [53.8 kB]
Get:127 http://httpredir.debian.org/debian buster/non-free armhf Packages [62.0 kB]
Get:128 http://httpredir.debian.org/debian buster/non-free Translation-en [88.8 kB]
Get:129 http://httpredir.debian.org/debian buster/non-free armhf Contents (deb) [779 kB]
Get:130 http://httpredir.debian.org/debian buster/non-free arm64 Contents (deb) [773 kB]
Get:131 http://httpredir.debian.org/debian buster-updates/non-free arm64 Packages [600 B]
Get:132 http://httpredir.debian.org/debian buster-updates/non-free armhf Packages [604 B]
Get:133 http://httpredir.debian.org/debian buster-updates/non-free Translation-en [673 B]
Get:134 http://httpredir.debian.org/debian buster-updates/non-free arm64 Contents (deb) [184 B]
Get:135 http://httpredir.debian.org/debian buster-updates/non-free armhf Contents (deb) [185 B]
Get:136 http://httpredir.debian.org/debian buster-backports/main armhf Packages [357 kB]
Get:137 http://httpredir.debian.org/debian buster-backports/main arm64 Packages [358 kB]
Get:138 http://httpredir.debian.org/debian buster-backports/main Translation-en [293 kB]
Get:139 http://httpredir.debian.org/debian buster-backports/main arm64 Contents (deb) [5,549 kB]
Get:140 http://httpredir.debian.org/debian buster-backports/main armhf Contents (deb) [5,959 kB]
Get:141 http://httpredir.debian.org/debian buster-backports/contrib armhf Packages [6,676 B]
Get:142 http://httpredir.debian.org/debian buster-backports/contrib arm64 Packages [6,408 B]
Get:143 http://httpredir.debian.org/debian buster-backports/non-free armhf Packages [9,892 B]
Get:144 https://uk.mirrors.fossho.st/armbian/apt buster/buster-utils armhf Packages [4,250 B]
Get:145 https://uk.mirrors.fossho.st/armbian/apt buster/buster-utils arm64 Packages [3,984 B]
Get:146 https://uk.mirrors.fossho.st/armbian/apt buster/buster-desktop arm64 Packages [1,072 B]
Get:147 https://uk.mirrors.fossho.st/armbian/apt buster/buster-desktop armhf Packages [2,092 B]
Get:148 https://uk.mirrors.fossho.st/armbian/apt buster/buster-desktop armhf Contents (deb) [563 B]
Get:149 https://uk.mirrors.fossho.st/armbian/apt buster/buster-desktop arm64 Contents (deb) [448 B]
Fetched 124 MB in 1min 32s (1,349 kB/s)
N: Repository 'http://httpredir.debian.org/debian buster InRelease' changed its 'Version' value from '10.3' to '10.5'
network-manager is already the newest version (1.14.6-2+deb10u1).
The following additional packages will be installed:
  apparmor libavahi-common-data libavahi-common3 libavahi-core7 libcurl4 libdbus-1-3 libjq1 libonig5 python3-apparmor python3-libapparmor
Suggested packages:
  apparmor-profiles-extra vim-addon-manager default-dbus-session-bus | dbus-session-bus
Recommended packages:
  libnss-mdns
The following NEW packages will be installed:
  apparmor apparmor-utils avahi-daemon jq libavahi-common-data libavahi-common3 libavahi-core7 libjq1 libonig5 python3-apparmor python3-libapparmor socat
The following packages will be upgraded:
  apt-transport-https ca-certificates curl dbus libcurl4 libdbus-1-3
6 upgraded, 12 newly installed, 0 to remove and 66 not upgraded.
Need to get 3,198 kB of archives.
After this operation, 6,312 kB of additional disk space will be used.
Get:1 http://httpredir.debian.org/debian buster/main arm64 dbus arm64 1.12.20-0+deb10u1 [227 kB]
Get:2 http://httpredir.debian.org/debian buster/main arm64 libdbus-1-3 arm64 1.12.20-0+deb10u1 [206 kB]
Get:3 http://httpredir.debian.org/debian buster/main arm64 apparmor arm64 2.13.2-10 [504 kB]
Get:4 http://httpredir.debian.org/debian buster/main arm64 python3-libapparmor arm64 2.13.2-10 [88.1 kB]
Get:5 http://httpredir.debian.org/debian buster/main arm64 python3-apparmor arm64 2.13.2-10 [141 kB]
Get:6 http://httpredir.debian.org/debian buster/main arm64 apparmor-utils arm64 2.13.2-10 [114 kB]
Get:7 http://httpredir.debian.org/debian buster/main arm64 apt-transport-https all 1.8.2.1 [149 kB]
Get:8 http://httpredir.debian.org/debian buster/main arm64 libavahi-common-data arm64 0.7-4+b1 [122 kB]
Get:9 http://httpredir.debian.org/debian buster/main arm64 libavahi-common3 arm64 0.7-4+b1 [53.5 kB]
Get:10 http://httpredir.debian.org/debian buster/main arm64 libavahi-core7 arm64 0.7-4+b1 [108 kB]
Get:11 http://httpredir.debian.org/debian buster/main arm64 avahi-daemon arm64 0.7-4+b1 [92.2 kB]
Get:12 http://httpredir.debian.org/debian buster-updates/main arm64 ca-certificates all 20200601~deb10u1 [158 kB]
Get:13 http://httpredir.debian.org/debian buster/main arm64 curl arm64 7.64.0-4+deb10u1 [260 kB]
Get:14 http://httpredir.debian.org/debian buster/main arm64 libcurl4 arm64 7.64.0-4+deb10u1 [312 kB]
Get:15 http://httpredir.debian.org/debian buster/main arm64 libonig5 arm64 6.9.1-1 [163 kB]
Get:16 http://httpredir.debian.org/debian buster/main arm64 libjq1 arm64 1.5+dfsg-2+b1 [103 kB]
Get:17 http://httpredir.debian.org/debian buster/main arm64 jq arm64 1.5+dfsg-2+b1 [58.7 kB]
Get:18 http://httpredir.debian.org/debian buster/main arm64 socat arm64 1.7.3.2-2 [339 kB]
Fetched 3,198 kB in 1s (2,199 kB/s)
Preconfiguring packages ...
(Reading database ... 34101 files and directories currently installed.)
Preparing to unpack .../00-dbus_1.12.20-0+deb10u1_arm64.deb ...
Unpacking dbus (1.12.20-0+deb10u1) over (1.12.16-1) ...
Preparing to unpack .../01-libdbus-1-3_1.12.20-0+deb10u1_arm64.deb ...
Unpacking libdbus-1-3:arm64 (1.12.20-0+deb10u1) over (1.12.16-1) ...
Selecting previously unselected package apparmor.
Preparing to unpack .../02-apparmor_2.13.2-10_arm64.deb ...
Unpacking apparmor (2.13.2-10) ...
Selecting previously unselected package python3-libapparmor.
Preparing to unpack .../03-python3-libapparmor_2.13.2-10_arm64.deb ...
Unpacking python3-libapparmor (2.13.2-10) ...
Selecting previously unselected package python3-apparmor.
Preparing to unpack .../04-python3-apparmor_2.13.2-10_arm64.deb ...
Unpacking python3-apparmor (2.13.2-10) ...
Selecting previously unselected package apparmor-utils.
Preparing to unpack .../05-apparmor-utils_2.13.2-10_arm64.deb ...
Unpacking apparmor-utils (2.13.2-10) ...
Preparing to unpack .../06-apt-transport-https_1.8.2.1_all.deb ...
Unpacking apt-transport-https (1.8.2.1) over (1.8.2) ...
Selecting previously unselected package libavahi-common-data:arm64.
Preparing to unpack .../07-libavahi-common-data_0.7-4+b1_arm64.deb ...
Unpacking libavahi-common-data:arm64 (0.7-4+b1) ...
Selecting previously unselected package libavahi-common3:arm64.
Preparing to unpack .../08-libavahi-common3_0.7-4+b1_arm64.deb ...
Unpacking libavahi-common3:arm64 (0.7-4+b1) ...
Selecting previously unselected package libavahi-core7:arm64.
Preparing to unpack .../09-libavahi-core7_0.7-4+b1_arm64.deb ...
Unpacking libavahi-core7:arm64 (0.7-4+b1) ...
Selecting previously unselected package avahi-daemon.
Preparing to unpack .../10-avahi-daemon_0.7-4+b1_arm64.deb ...
Unpacking avahi-daemon (0.7-4+b1) ...
Preparing to unpack .../11-ca-certificates_20200601~deb10u1_all.deb ...
Unpacking ca-certificates (20200601~deb10u1) over (20190110) ...
Preparing to unpack .../12-curl_7.64.0-4+deb10u1_arm64.deb ...
Unpacking curl (7.64.0-4+deb10u1) over (7.64.0-4) ...
Preparing to unpack .../13-libcurl4_7.64.0-4+deb10u1_arm64.deb ...
Unpacking libcurl4:arm64 (7.64.0-4+deb10u1) over (7.64.0-4) ...
Selecting previously unselected package libonig5:arm64.
Preparing to unpack .../14-libonig5_6.9.1-1_arm64.deb ...
Unpacking libonig5:arm64 (6.9.1-1) ...
Selecting previously unselected package libjq1:arm64.
Preparing to unpack .../15-libjq1_1.5+dfsg-2+b1_arm64.deb ...
Unpacking libjq1:arm64 (1.5+dfsg-2+b1) ...
Selecting previously unselected package jq.
Preparing to unpack .../16-jq_1.5+dfsg-2+b1_arm64.deb ...
Unpacking jq (1.5+dfsg-2+b1) ...
Selecting previously unselected package socat.
Preparing to unpack .../17-socat_1.7.3.2-2_arm64.deb ...
Unpacking socat (1.7.3.2-2) ...
Setting up python3-libapparmor (2.13.2-10) ...
Setting up apt-transport-https (1.8.2.1) ...
Setting up apparmor (2.13.2-10) ...
Created symlink /etc/systemd/system/sysinit.target.wants/apparmor.service → /lib/systemd/system/apparmor.service.
Setting up ca-certificates (20200601~deb10u1) ...
Updating certificates in /etc/ssl/certs...
13 added, 15 removed; done.
Setting up libavahi-common-data:arm64 (0.7-4+b1) ...
Setting up socat (1.7.3.2-2) ...
Setting up libdbus-1-3:arm64 (1.12.20-0+deb10u1) ...
Setting up dbus (1.12.20-0+deb10u1) ...
A reboot is required to replace the running dbus-daemon.
Please reboot the system when convenient.
Setting up python3-apparmor (2.13.2-10) ...
Setting up libcurl4:arm64 (7.64.0-4+deb10u1) ...
Setting up curl (7.64.0-4+deb10u1) ...
Setting up libonig5:arm64 (6.9.1-1) ...
Setting up libjq1:arm64 (1.5+dfsg-2+b1) ...
Setting up libavahi-common3:arm64 (0.7-4+b1) ...
Setting up apparmor-utils (2.13.2-10) ...
Setting up jq (1.5+dfsg-2+b1) ...
Setting up libavahi-core7:arm64 (0.7-4+b1) ...
Setting up avahi-daemon (0.7-4+b1) ...
Created symlink /etc/systemd/system/dbus-org.freedesktop.Avahi.service → /lib/systemd/system/avahi-daemon.service.
Created symlink /etc/systemd/system/multi-user.target.wants/avahi-daemon.service → /lib/systemd/system/avahi-daemon.service.
Created symlink /etc/systemd/system/sockets.target.wants/avahi-daemon.socket → /lib/systemd/system/avahi-daemon.socket.
Processing triggers for systemd (241-7~deb10u2) ...
Processing triggers for man-db (2.8.5-2) ...
/usr/bin/mandb: can't chmod /var/cache/man/sr/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/sr/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/sr/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/ja/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/ja/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/ja/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/ko/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/ko/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/ko/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/pt_BR/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/pt_BR/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/pt_BR/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/ru/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/ru/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/ru/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/it/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/it/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/it/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/fr/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/fr/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/fr/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/de/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/de/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/de/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/da/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/da/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/da/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/nl/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/nl/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/nl/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/zh_CN/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/zh_CN/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/zh_CN/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/gl/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/gl/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/gl/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/cs/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/cs/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/cs/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/fr.UTF-8/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/fr.UTF-8/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/fr.UTF-8/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/hu/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/hu/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/hu/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/pt/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/pt/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/pt/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/fi/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/fi/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/fi/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/pl/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/pl/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/pl/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/fr.ISO8859-1/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/fr.ISO8859-1/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/fr.ISO8859-1/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/sl/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/sl/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/sl/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/zh_TW/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/zh_TW/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/zh_TW/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/sv/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/sv/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/sv/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/tr/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/tr/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/tr/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/es/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/es/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/es/7149: Permission denied
/usr/bin/mandb: can't chmod /var/cache/man/id/CACHEDIR.TAG: Operation not permitted
/usr/bin/mandb: can't remove /var/cache/man/id/CACHEDIR.TAG: Permission denied
/usr/bin/mandb: fopen /var/cache/man/id/7149: Permission denied
Processing triggers for libc-bin (2.28-10) ...
Processing triggers for ca-certificates (20200601~deb10u1) ...
0 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
Processing triggers for dbus (1.12.20-0+deb10u1) ...
# Executing docker install script, commit: 26ff363bcf3b3f5a00498ac43694bf1c7d9ce16c
+ sh -c apt-get update -qq >/dev/null
+ sh -c DEBIAN_FRONTEND=noninteractive apt-get install -y -qq apt-transport-https ca-certificates curl >/dev/null
+ sh -c curl -fsSL "https://download.docker.com/linux/debian/gpg" | apt-key add -qq - >/dev/null
Warning: apt-key output should not be parsed (stdout is not a terminal)
+ sh -c echo "deb [arch=arm64] https://download.docker.com/linux/debian buster stable" > /etc/apt/sources.list.d/docker.list
+ [ -n  ]
+ sh -c apt-get install -y -qq --no-install-recommends docker-ce >/dev/null
+ sh -c docker version
Client: Docker Engine - Community
 Version:           19.03.12
 API version:       1.40
 Go version:        go1.13.10
 Git commit:        48a6621
 Built:             Mon Jun 22 15:47:06 2020
 OS/Arch:           linux/arm64
 Experimental:      false
Server: Docker Engine - Community
 Engine:
  Version:          19.03.12
  API version:      1.40 (minimum version 1.12)
  Git commit:       48a6621
  Built:            Mon Jun 22 15:45:37 2020
  Experimental:     false
 containerd:
  Version:          1.2.13
  GitCommit:        7ad184331fa3e55e52b890ea95e65ba581ae3429
 runc:
  Version:          1.0.0-rc10
  GitCommit:        dc9208a3303feef5b3839f4323d9beb36df0a9dd
 docker-init:
  Version:          0.18.0
  GitCommit:        fec3683
If you would like to use Docker as a non-root user, you should now consider
adding your user to the "docker" group with something like:
  sudo usermod -aG docker your-user
Remember that you will have to log out and back in for this to take effect!
WARNING: Adding a user to the "docker" group will grant the ability to run
         containers which can be used to obtain root privileges on the
         docker host.
         Refer to https://docs.docker.com/engine/security/security/#docker-daemon-attack-surface
         for more information.
[Warning] This installer is no longer supported.
[Warning]
[Warning] Home Assistant might work today, tomorrow maybe not.
[Warning]
[Warning] If you want more control over your own system, run
[Warning] Home Assistant as a VM or run Home Assistant Core
[Warning] via a Docker container.
[Warning]
[Info] Install supervisor Docker container
[Info] Install supervisor startup scripts
Created symlink /etc/systemd/system/multi-user.target.wants/hassio-supervisor.service → /etc/systemd/system/hassio-supervisor.service.
[Info] Install AppArmor scripts
Created symlink /etc/systemd/system/multi-user.target.wants/hassio-apparmor.service → /etc/systemd/system/hassio-apparmor.service.
[Info] Run Hass.io
[Info] Install cli 'ha'
http://armhassio.local:8123/ in your browser and wait
If the previous URL does not work, please try http://192.168.1.51:8123/
Fiz reboot à box e corri o arm-config e as apps já aparecem instaladas mas nada de HA na mesma :frowning:
Que acontece quando das este comando?
Pois ele está instalado… Já exprimentaste noutro browser?
Yap… até no telemóvel e nada!
Vou fazer tudo de novo :frowning:
Instala uma versão Buster sem desktop
Agora vai levar com esta…
Armbian_20.08_Arm-64_buster_current_5.7.16.img
EDIT: Teve que ser com a Armbian_20.07_Arm-64_buster_current_5.7.9.img.xz e instalar o DOCKER e O HA pelo Armbian-Config
Menos uma dor de cabeça :slight_smile:
Obrigado malta… agora tenho mt que fazer por aqui :stuck_out_tongue:
boa noite…
tenho a minha box cheia …
já me dá erro no terminal:
E: Write error - ~LZMAFILE (28: No space left on device)
a fazer ap-get update e upgrade:
a pasta var/log esta 100 % ocupada … sao 48 M …
como posso resolver ?
thanks …
acho q apaguei coisas a mais que agora o meu ha nao abre…
e no container só 2 é que estao em execuçao ’
se os seleçionar manual e mandar executar … ha 4 que nao executam…
e acho q é por isso q nao tenho ha …
ALGUEM ME PODE AJUDAR ?
thanks …
tou sem home assistant… :frowning:
sim @RodolfoVieira @Maddoctor
só tenho acesso por ssh:
nao tenho nem samba nem ftp … so acesso ssh
O portainer deixou de ser suportado recentemente. Instalações onde o supervisor está a correr é demasiado arriscado utilizar o portainer para fazer qualquer alteração com o risco do que agora relatas. Será difícil tentar ajudar a recuperar com a informação apresentada aliado a não estares recordado do que apagaste.
A minha recomendação para evitares perder tempo e não teres sucesso será nova instalação e recuperação dos backups de forma a garantir o correto funcionamento e um futuro ambiente estável.
ok, e entao como é que posso fazer para apagar tudo o q tenho aqui … nao deixar restos … de ficheiros a ocupar espaço, na box e fazer uma instalaçao limpa para depois repor tudo ? com o backup ? faço rm qualquer coisa ? no terminal ? @Luis_Andrade thanks
O procedimento será igual a uma instalação nova para limpar tudo. A parte da reposição do teu HA é feita pelo ficheiro de restore dos backups quando solicitado no ecrã inicial ou mais tarde dentro do ambiente.
entao terei de fazer novame-te gravar novamente o cartao sd… e seguir este tutorial:
a imagem dele ainda esta actual ou esta desatualizada ?
https://disk.yandex.ru/d/_rQgn_FosYuW0g/20.05/20200213
pensei q desse para apagando os diretorios todos … e instalando de novo, á q tenho ssh …
thanks
ao repor o backup ele nao me vai instalar novamente o portainer q deixou de ser suportado e vou ter o mesmo problema ?
@Luis_Andrade
Tens no fórum posts atualizados para esse tema. Relativamente ao portainer, podes escolher quais os addons que pretendes repor no momento do restore, bastando para tal não selecionar o referido.
O q está actualizado não é o link k enviei ?
Eu não tinha o docker portainer instalado por addon … acho k o tinha instalado via sh… terminal .
