Zigbee2MQTT ERRO
Tinha o Zigbee2MQTT a funcionar corretamente e sem problemas com uma conbee. Ainda não tinha nenhum dispositivo Zigbee e por isso era algo que estava ali arrumado e nem sequer mexia. No entanto estes dias fui lá tentar abrir a interface web e não funcionava.
O meu log dá sempre estes erros:
[09:46:18] INFO: Preparing to start…
[09:46:19] INFO: Socat not enabled
[09:46:22] INFO: Starting Zigbee2MQTT…
Zigbee2MQTT:info 2023-08-30 09:46:31: Logging to console and directory: ‘/config/zigbee2mqtt/log/2023-08-30.09-46-31’ filename: log.txt
Zigbee2MQTT:info 2023-08-30 09:46:31: Starting Zigbee2MQTT version 1.32.2 (commit #unknown)
Zigbee2MQTT:info 2023-08-30 09:46:31: Starting zigbee-herdsman (0.17.2)
Zigbee2MQTT:error 2023-08-30 09:46:32: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-08-30 09:46:32: Failed to start zigbee
Zigbee2MQTT:error 2023-08-30 09:46:32: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-08-30 09:46:32: Exiting…
Zigbee2MQTT:error 2023-08-30 09:46:32: Error: Error while opening serialport ‘Error: Error: Resource busy, cannot open /dev/ttyACM0’
at SerialPort. (/app/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:200:28)
at SerialPort._error (/app/node_modules/@serialport/stream/dist/index.js:75:22)
at /app/node_modules/@serialport/stream/dist/index.js:111:18
A minha configuração é esta:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: “-d -d”
log: false
mqtt:
base_topic: zigbee2mqtt
user: teste
password: teste
serial:
port: /dev/ttyACM0
adapter: deconz
external_converters:
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
advanced:
log_level: error
pan_id: 6754
channel: 11
network_key:
- 1
- 3
- 5
- 7
- 9
- 11
- 13
- 15
- 0
- 2
- 4
- 6
- 8
- 10
- 12
- 13
availability_blocklist:
availability_passlist:
device_options: {}
blocklist:
passlist:
queue: {}
frontend:
port: 8099
experimental: {}
Alguém me consegue ajudar a resolver este problema?
Desde já agradeço.
Experimenta meter desta maneira o serial:
port: >-
  /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2215419-if00
adapter: deconz
Já tentei e continua a não funcionar. Mais alguma dica?
