De repente, deixei de conseguir ter a minha rede zigbee a funcionar.
LOG addon zigbee2mqtt:
./run.sh: line 16: [Info] Configuration backup found in /share/zigbee2mqtt/.configuration.yaml.bk. Skipping config backup.: No such file or directory
2019-09-02T11:47:40: PM2 log: Launching in no daemon mode
2019-09-02T11:47:40: PM2 log: App [npm:0] starting in -fork mode-
2019-09-02T11:47:40: PM2 log: App [npm:0] online
> zigbee2mqtt@1.5.1 start /zigbee2mqtt-1.5.1
> node index.js
zigbee2mqtt:info 9/2/2019, 11:47:41 AM Logging to directory: '/share/zigbee2mqtt/log/2019-09-02.11-47-41'
zigbee2mqtt:info 9/2/2019, 11:47:41 AM Starting zigbee2mqtt version 1.5.1 (commit #unknown)
zigbee2mqtt:info 9/2/2019, 11:47:41 AM Starting zigbee-shepherd
zigbee2mqtt:info 9/2/2019, 11:47:48 AM Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds) (Error: request timeout)
zigbee2mqtt:info 9/2/2019, 11:48:48 AM Starting zigbee-shepherd
zigbee2mqtt:error 9/2/2019, 11:48:55 AM Error while starting zigbee-shepherd! (Error: request timeout)
zigbee2mqtt:error 9/2/2019, 11:48:55 AM Press the reset button on the stick (the one closest to the USB) and start again
zigbee2mqtt:error 9/2/2019, 11:48:55 AM Failed to start
{"message":"request timeout","stack":"Error: request timeout\n at CcZnp.<anonymous> (/zigbee2mqtt-1.5.1/node_modules/zigbee-herdsman/dist/cc-znp/index.js:208:22)\n at Object.onceWrapper (events.js:286:20)\n at CcZnp.emit (events.js:198:13)\n at Timeout.<anonymous> (/zigbee2mqtt-1.5.1/node_modules/zigbee-herdsman/dist/cc-znp/index.js:192:18)\n at ontimeout (timers.js:436:11)\n at tryOnTimeout (timers.js:300:5)\n at listOnTimeout (timers.js:263:5)\n at Timer.processTimers (timers.js:223:10)"}
zigbee2mqtt:error 9/2/2019, 11:48:55 AM Exiting...
npm
ERR! code ELIFECYCLE
npm ERR! errno 1
npm
ERR! zigbee2mqtt@1.5.1 start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.5.1 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2019-09-02T10_48_55_944Z-debug.log
2019-09-02T11:49:00: PM2 log: App [npm:0] exited with code [1] via signal [SIGINT]
2019-09-02T11:49:00: PM2 log: App [npm:0] starting in -fork mode-
2019-09-02T11:49:00: PM2 log: App [npm:0] online
> node index.js
zigbee2mqtt:info 9/2/2019, 11:49:01 AM Logging to directory: '/share/zigbee2mqtt/log/2019-09-02.11-49-01'
zigbee2mqtt:info 9/2/2019, 11:49:01 AM Starting zigbee2mqtt version 1.5.1 (commit #unknown)
zigbee2mqtt:info 9/2/2019, 11:49:01 AM Starting zigbee-shepherd
zigbee2mqtt:info 9/2/2019, 11:49:08 AM Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds) (Error: request timeout)
zigbee2mqtt:info 9/2/2019, 11:50:08 AM Starting zigbee-shepherd
zigbee2mqtt:error 9/2/2019, 11:50:15 AM Error while starting zigbee-shepherd! (Error: request timeout)
zigbee2mqtt:error 9/2/2019, 11:50:15 AM Press the reset button on the stick (the one closest to the USB) and start again
zigbee2mqtt:error 9/2/2019, 11:50:15 AM Failed to start
zigbee2mqtt:error 9/2/2019, 11:50:15 AM Exiting...
npm
npm ERR! errno 1
npm
npm ERR!
npm ERR!
npm ERR! /root/.npm/_logs/2019-09-02T10_50_15_862Z-debug.log
2019-09-02T11:50:15: PM2 log: App [npm:0] exited with code [1] via signal [SIGINT]
2019-09-02T11:50:15: PM2 log: App [npm:0] starting in -fork mode-
2019-09-02T11:50:15: PM2 log: App [npm:0] online
> node index.js
zigbee2mqtt:info 9/2/2019, 11:50:17 AM Logging to directory: '/share/zigbee2mqtt/log/2019-09-02.11-50-16'
zigbee2mqtt:info 9/2/2019, 11:50:17 AM Starting zigbee2mqtt version 1.5.1 (commit #unknown)
zigbee2mqtt:info 9/2/2019, 11:50:17 AM Starting zigbee-shepherd
Verifiquei no dmesg no ubuntu :
cdc_acm 3-1:1.0: failed to set dtr/rts
Alguém me pode ajudar ?
