E qual é exactamente o endereço a que estás a tentar aceder? Coloca aqui uma captura de ecrã do endereço e do erro.
O endereço está correcto, resta saber se de facto é esse o IP.
acho que já houve outra mudança na instalaçao do HA:
ao instalar dá ese erro:
dpkg -i homeassistant-supervised.deb
Selecting previously unselected package homeassistant-supervised.
(Reading database … 36554 files and directories currently installed.)
Preparing to unpack homeassistant-supervised.deb …
[warn]
[warn] If you want more control over your own system, run
[warn] Home Assistant as a VM or run Home Assistant Core
[warn] via a Docker container.
[warn]
Adding ‘diversion of /etc/NetworkManager/NetworkManager.conf to /etc/NetworkManager/NetworkManager.conf.real by homeassistant-supervised’
Adding ‘diversion of /etc/NetworkManager/system-connections/default to /etc/NetworkManager/system-connections/default.real by homeassistant-supervised’
Adding ‘diversion of /etc/docker/daemon.json to /etc/docker/daemon.json.real by homeassistant-supervised’
Adding ‘diversion of /etc/network/interfaces to /etc/network/interfaces.real by homeassistant-supervised’
Unpacking homeassistant-supervised (1.0.2) …
dpkg: dependency problems prevent configuration of homeassistant-supervised:
homeassistant-supervised depends on os-agent; however:
Package os-agent is not installed.
dpkg: error processing package homeassistant-supervised (–install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
porque dá erro no Package os-agent is not installed.
ao tentar instalar :
não tem o deb. para o arm-64 bits (para a minha box w95 armbien (debian))
como resolver ?
obrigado …
1 - O OS agente é esse, basta fazer um comando por vez:
wget https://github.com/home-assistant/os-agent/releases/download/1.2.1/os-agent_1.2.1_linux_aarch64.deb
dpkg -i os-agent_1.2.1_linux_aarch64.deb
2 - Depois tentar seguir a sequencia abaixo:
apt-get update
apt-get install udisks2 wget
curl -sL https://raw.githubusercontent.com/MadDoct/hassio-installer/master/hassio_s9xxarmbian.sh | bash -sv
3 - Se der algum erro, basta digitar o comando:
apt-get --allow-releaseinfo-change update
E tenta voltar ao passo 2.
1 - Tente dar o comando:
2 - Siga a sequencia abaixo novamente:
apt-get update
sim foi assim q resolvi …
o nikito tb me disse:
wget -c https://github.com/home-assistant/os-agent/releases/download/1.2.2/os-agent_1.2.2_linux_aarch64.deb
dpkg -i os-agent_1.2.2_linux_aarch64.deb
obrigado
já funciona
Boa noite,
Já confirmei o IP e está correto. Já tentei pelo que o @Leonardocruzrj postou e nada… o que não me aparece é a tela para escolher “qemuarm-64” … será problema no ARMBIAN??? alguém que me consiga ajudar? já estou a fritar os miolos…
Tenta fazer esses comandos em sequencia e depois inicia o tuto do início.
apt-get clean
apt-get update
Boa Tarde, agradeço a ajuda, mas tudo na mesma… continua a dar o erro (404) entre o comando “curl -sL https://raw.githubusercontent.com/MadDoct/hassio-installer/master/hassio_s9xxarmbian.sh | bash -sv” e o comando “wget https://github.com/home-assistant/supervised-installer/releases/latest/download/homeassistant-supervised.deb” é normal?
Poderá ser problema na instalação do meu ARMBIAN???
ola eu tambem estou com problema , para inserir o HOME ASSISTANT . bom eu tentei de duas formas com script da erro (404) ja tentei de varias maneiras mudei ate o script conseguir sair do erro 404 . porem caio ne outro erro .que vou deixar logo a baixo os dois erros .
@Leonardocruzrj Jose EU FIZ TODAS SUAS OPERAÇOES , porem eu fico nesse erro aqui ao utilizar esse comando
da esse erro aqui >>>
dpkg: error processing archive os-agent_1.2.1_linux_aarch64.deb (--install):
package architecture (arm64) does not match system (armhf)
**JA NO OUTRO METODO QUE TENTEI **
UTILIZANDO PROPRIO SCRIPT DAQUI MODIFIQUEI O LINK COM ERRO 404 , COLOQUEI UM QUE NAO TIVESSE APRESENTANDO ERRO .POREM CAIO NE OUTRO ERRO
sicrip modicado por mim
curl -sL https://raw.githubusercontent.com/bbeckann/HA/main/AAAA | sudo bash -sv
erro apresentado .
Installing Hass.io...
[Info] Install supervisor Docker container
[Info] Install supervisor startup scripts
Failed to enable unit: File hassio-supervisor.service: Invalid argument
root@armhassio:/home/mbeckann#
No primeiro erro basta ler o que lá está escrito… Se o erro diz que que a arquitetura do ficheiro é a errada (aarch64), basta mudar para a arquitetura certa (armhf).
Muito obrigado pelo seu retorno, eu acabei lendo exatamente isso que você me apresentou . Porém você conhece como muda arquitetura do sistema para eu tá efetuando implementação do Home Assistant ? . Desde já agradeço seu retorno .
Sim, basta usar o ficheiro correcto para a arquitetura pretendida. Onde estás a ir buscar esse ficheiro deverá lá existir um para armhf.
Bom , tal ficheiros estava apresentado aqui nos tutoriais do @Leonardocruzrj .
Vou da uma pequena procurada nas opções , realizar alguns teste , mas se você soube como muda só sistema para outro , ou até mesmo o ficheiro específico deix aQui os comando , vai ser de soma importância .
Amigos, o erro 404 é normal, ele vai existir sempre, porque o script mudou.
O comando curl -sL https://raw.githubusercontent.com/MadDoct/hassio-installer/master/hassio_s9xxarmbian.sh | bash -sv é utilizado apenas para instalar as dependências (Apparmor , Docker, etc…), basta ignorar o erro 404, não vai mudar nada.
Basta continuar a instalação com os comando seguintes, esses sim irão instalar o HA.
Os ficheiros de os-agente que estão na minha postagem são para o processador arm64 que é o processador utilizado na TX3 que é o alvo desse tópico. Para outras box que tem outras arquiteturas vc tem que usar os os-agentes desse link:
São os que tem final .deb:
O do seu processador provavelmente é o armv7, teste esses comandos em substituição aos meus:
wget https://github.com/home-assistant/os-agent/releases/download/1.2.1/os-agent_1.2.2_linux_armv7.deb
dpkg -i os-agent_1.2.2_linux_armv7.deb
infelizmente cair nessa etapa … que foi mesmo detalhe do meu amigo acima espero , que voces possa me passa alternativa kkkk …
minha instalacao tambem ocorreu sem probleas mas nao acesso ao ip do HA.
Que box vocês estão a usar? Tanix tx3?
