Desde há alguns dias que o meu HA tem deixado de funcionar sem que consiga perceber o motivo e apenas o reactivo fazendo reboot ao raspberry pi via ssh.
Não encontro nada de relevante no home-assistant.log antes da paragem fo HA
Apenas tenho acesso ao system.log de rearranque e as mensagens a vermelho na ultima vez foram:
19-05-20 05:39:42 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
19-05-20 05:39:42 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
19-05-20 05:40:07 ERROR (SyncWorker_13) [hassio.docker] Can't start addon_core_ssh: 500 Server Error: Internal Server Error ("driver failed programming external connectivity on endpoint addon_core_ssh (2d3b5d1adaf0560a54b333e658821a1b32b8106bb60f1c4162aafe8d7c89e5f7): Error starting userland proxy: listen tcp 0.0.0.0:22: bind: address already in use")
19-05-20 05:40:10 ERROR (MainThread) [asyncio] Task exception was never retrieved future: <Task finished coro=<Addon.start() done, defined at /usr/src/hassio/hassio/addons/addon.py:459> exception=AddonsError()> Traceback (most recent call last): File "/usr/src/hassio/hassio/addons/addon.py", line 479, in start raise AddonsError() from None
Como referi o meu HA está instalado em rbp 3B
Hass.io supervisor: 163
System: Raspbian GNU/Linux 9 (stretch)
System Health
| arch | armv7l |
| dev | false |
| docker | true |
| hassio | true |
| os_name | Linux |
| python_version | 3.7.3 |
| timezone | Europe/Lisbon |
| version | 0.92.2 |
| virtualenv | false |
Alguma sugestão como investigar a origem deste problema?
