Boa tarde, estou com problemas no meu homeassistant e ficava muito agradecido se alguém me conseguisse indicar o que fiz de mal.
Tenho o home assistant instalado num raspberry pi com docker e devo ter feito alguma coisa mal que após um reboot o mesmo deixou de funcionar.
Tenho o portainer instalado e aí dá para ver que todos os outros containers arrancam sem problema, o container homeassistant é que está com problemas no arranque.
Seguem os logs que o portainer devolve no arranque do home assistant, pode ser que ajude
[s6-finish] sending all processes the KILL signal and exiting.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[18:43:30] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
File "/usr/local/lib/python3.8/runpy.py", line 194, in _run_module_as_main
return _run_code(code, main_globals, None,
File "/usr/local/lib/python3.8/runpy.py", line 87, in _run_code
exec(code, run_globals)
File "/usr/src/homeassistant/homeassistant/__main__.py", line 320, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 278, in main
args = get_arguments()
File "/usr/src/homeassistant/homeassistant/__main__.py", line 60, in get_arguments
import homeassistant.config as config_util
File "/usr/src/homeassistant/homeassistant/config.py", line 61, in <module>
from homeassistant.util.yaml import SECRET_YAML, load_yaml
File "/usr/src/homeassistant/homeassistant/util/yaml/__init__.py", line 4, in <module>
from .loader import clear_secret_cache, load_yaml, parse_yaml, secret_yaml
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 17, in <module>
import keyring
File "/usr/local/lib/python3.8/site-packages/keyring/__init__.py", line 1, in <module>
from .core import (
File "/usr/local/lib/python3.8/site-packages/keyring/core.py", line 192, in <module>
init_backend()
File "/usr/local/lib/python3.8/site-packages/keyring/core.py", line 96, in init_backend
filter(limit, backend.get_all_keyring()),
File "/usr/local/lib/python3.8/site-packages/keyring/util/__init__.py", line 22, in wrapper
func.always_returns = func(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/keyring/backend.py", line 216, in get_all_keyring
_load_plugins()
File "/usr/local/lib/python3.8/site-packages/keyring/backend.py", line 199, in _load_plugins
entry_points = metadata.entry_points()['keyring.backends']
File "/usr/local/lib/python3.8/importlib/metadata.py", line 542, in entry_points
ordered = sorted(eps, key=by_group)
File "/usr/local/lib/python3.8/importlib/metadata.py", line 540, in <genexpr>
dist.entry_points for dist in distributions())
File "/usr/local/lib/python3.8/importlib/metadata.py", line 240, in entry_points
return EntryPoint._from_text(self.read_text('entry_points.txt'))
File "/usr/local/lib/python3.8/importlib/metadata.py", line 100, in _from_text
config.read_string(text)
File "/usr/local/lib/python3.8/configparser.py", line 723, in read_string
self.read_file(sfile, source)
File "/usr/local/lib/python3.8/configparser.py", line 718, in read_file
self._read(f, source)
File "/usr/local/lib/python3.8/configparser.py", line 1082, in _read
raise MissingSectionHeaderError(fpname, lineno, line)
configparser.MissingSectionHeaderError: File contains no section headers.
file: '<string>', line: 1
'B14C095EA130E0B9938A5E22FC52650F591\n'
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
Obrigado desde já.
