Zigbee2mqtt 1a instalação
Boa noite, ao fim de experimentar diversas soluçoes que fui vendo por a net ainda não consegui que funcione o zigbee2mqtt, alguém fez a instalação recentemente que me possa ajudar? segui o tutorial aqui do forum mas a versao mais atual do addon nao me deixa gravar as configs do addon…
a minha config do addon:
  "data_path": "/share/zigbee2mqtt",
  "devices": "devices.yaml",
  "groups": "groups.yaml",
  "homeassistant": true,
  "permit_join": true,
  "mqtt": {
    "base_topic": "zigbee2mqtt",
    "server": "http://192.168.x.y"
    "user": "meuusermqtt",
    "password": "minhapassmqtt"
  "serial": {
    "port": "/dev/ttyAMA0"
  "advanced": {
    "pan_id": 6754,
    "channel": 11,
    "network_key": [
      1,
      3,
      5,
      7,
      9,
      11,
      13,
      15,
      0,
      2,
      4,
      6,
      8,
      10,
      12,
      13
    "availability_blacklist": []
  "ban": [],
  "whitelist": [],
  "queue": {}
o meu log :
./run.sh: line 16: [Info] Configuration backup found in /share/zigbee2mqtt/.configuration.yaml.bk. Skipping config backup.: No such file or directory
2019-08-04T00:47:29: PM2 log: Launching in no daemon mode
2019-08-04T00:47:30: PM2 log: App [npm:0] starting in -fork mode-
2019-08-04T00:47:30: PM2 log: App [npm:0] online
> zigbee2mqtt@1.5.1 start /app
> node index.js
  zigbee2mqtt:info 8/4/2019, 12:47:35 AM Logging to directory: '/share/zigbee2mqtt/log/2019-08-04.00-47-34'
  zigbee2mqtt:info 8/4/2019, 12:47:36 AM Starting zigbee2mqtt version 1.5.1 (commit #unknown)
  zigbee2mqtt:info 8/4/2019, 12:47:36 AM Starting zigbee-shepherd
  zigbee2mqtt:info 8/4/2019, 12:47:49 AM Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds) (Error: timeout)
  zigbee2mqtt:info 8/4/2019, 12:48:49 AM Starting zigbee-shepherd
  zigbee2mqtt:error 8/4/2019, 12:49:02 AM Error while starting zigbee-shepherd! (Error: timeout)
  zigbee2mqtt:error 8/4/2019, 12:49:02 AM Press the reset button on the stick (the one closest to the USB) and start again
  zigbee2mqtt:error 8/4/2019, 12:49:02 AM Failed to start
	{"message":"timeout","stack":"Error: timeout\n    at Timeout.setTimeout [as _onTimeout] (/app/node_modules/zigbee-herdsman/dist/znp/znp.js:157:24)\n    at ontimeout (timers.js:436:11)\n    at tryOnTimeout (timers.js:300:5)\n    at listOnTimeout (timers.js:263:5)\n    at Timer.processTimers (timers.js:223:10)"}
  zigbee2mqtt:error 8/4/2019, 12:49:02 AM Exiting...
npm
 ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! zigbee2mqtt@1.5.1 start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.5.1 start script.
npm
 ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2019-08-03T23_49_02_391Z-debug.log
2019-08-04T00:49:06: PM2 log: App [npm:0] exited with code [1] via signal [SIGINT]
2019-08-04T00:49:06: PM2 log: App [npm:0] starting in -fork mode-
2019-08-04T00:49:06: PM2 log: App [npm:0] online
> node index.js
  zigbee2mqtt:info 8/4/2019, 12:49:11 AM Logging to directory: '/share/zigbee2mqtt/log/2019-08-04.00-49-10'
  zigbee2mqtt:info 8/4/2019, 12:49:11 AM Starting zigbee2mqtt version 1.5.1 (commit #unknown)
  zigbee2mqtt:info 8/4/2019, 12:49:11 AM Starting zigbee-shepherd
  zigbee2mqtt:info 8/4/2019, 12:49:25 AM Error while starting zigbee-shepherd, attempting to fix... (takes 60 seconds) (Error: timeout)
  zigbee2mqtt:info 8/4/2019, 12:50:25 AM Starting zigbee-shepherd
Alguma ideia?
obrigado
Para já, falta uma virgula depois de "server": "http://192.168.x.y". Depois confirma se o teu device está mesmo na porta /dev/ttyAMA0.
A luz da pen zigbee está ligada? Por vezes desligar e voltar a ligar a pen imediatamente antes de reiniciar o addon resolve alguns problemas.
É muito estranho que a “porta” seja essa… Se estás a usar o rpi3b, essa é a porta do Bluetooth…
Muito obrigado , ja funciona.
A virgula que faltava foi ao colarr aqui no forum e editar para esconder os dados pessoais, na verdade nas config tem virgula.
De facto a porta da pen estava errada pois era a unica que me aparecia no hardware como ligada, após desligar e voltar a ligar a pen apareceu a porta correta e tudo começou a funcionar corretamente.
Mais uma vez obrigado e desculpem qualquer coisa.
Um abraço
