Zigbee deixou de funcionar
Boa noite,
Eu tenho uma pen CC2531, e tudo estava a funcionar bem. Do nada falhou, já desliguei e ligue a pen, mudei a porta USB, repus um screenshot e nada…
No log do Zigbee2mqtt tem :
at Timeout._onTimeout (/zigbee2mqtt-1.16.1/node_modules/zigbee-herdsman/dist/utils/waitress.js:46:35)
    at listOnTimeout (internal/timers.js:549:17)
    at processTimers (internal/timers.js:492:7)
npm
 ERR! code ELIFECYCLE
npm ERR! errno 1
npm
 ERR! zigbee2mqtt@1.16.1 start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.16.1 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2020-11-24T23_27_08_991Z-debug.log
2020-11-24T23:27:09: PM2 log: App [npm:0] exited with code [1] via signal [SIGINT]
2020-11-24T23:27:09: PM2 log: App [npm:0] starting in -fork mode-
2020-11-24T23:27:09: PM2 log: App [npm:0] online
> zigbee2mqtt@1.16.1 start /zigbee2mqtt-1.16.1
> node index.js
Zigbee2MQTT:info  2020-11-24 23:27:13: Logging to console and directory: '/share/zigbee2mqtt/log/2020-11-24.23-27-12' filename: log.txt
Zigbee2MQTT:info  2020-11-24 23:27:13: Starting Zigbee2MQTT version 1.16.1 (commit #1.16.1)
Zigbee2MQTT:info  2020-11-24 23:27:13: Starting zigbee-herdsman...
Zigbee2MQTT:error 2020-11-24 23:28:15: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2020-11-24 23:28:15: Failed to start zigbee
Zigbee2MQTT:error 2020-11-24 23:28:15: Exiting...
Zigbee2MQTT:error 2020-11-24 23:28:15: Error: AREQ - ZDO - stateChangeInd after 60000ms
Mas não sei como chegar ao ficheiro de log…
No file editor está na pasta config e não deixa subir um nível. E pelo samba não aparece a dita pasta… Apenas tem na root : addons, backup, config, media, share e ssl…
Qualquer ajuda agradeço.
Entretanto re-Flashei a minha pen CC2531 e voltou tudo ao normal…
Mas passado umas horas, o mesmo problema…
Em que máquina estás a correr o HA?
Viva Jorge,
RPi 4 de 2gb.
E que fonte de alimentação estás a usar? Esse problema poderá ter a ver com a alimentação da pen. Ou usas uma fonte de alimentação própria para Rpi ou fazes o que já aqui tem sido dito por diversas vezes e usas um hub USB com alimentação externa e uma extensão USB2.0 para afastar a pen do Rpi.
Eu estou a usar a fonte de alimentação original do Raspberry pi 4.
E a pen zigbee está ligada à porta USB3 do Raspberry Pi…
Então tenta a outra opção que te dei.
