UPDATE Hassio 0.108.8 -> atual
Não estou a conseguir fazer o update da V 0.108.8 -> atual, mando executar a atualização através do Hassio, mas não faz. No log não apresenta nada.
20-05-22 18:33:09 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.110.1
20-05-22 18:33:09 INFO (SyncWorker_5) [supervisor.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.108.8 to homeassistant/raspberrypi3-homeassistant:0.110.1
20-05-22 18:33:09 INFO (SyncWorker_5) [supervisor.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.110.1.
20-05-22 18:37:26 INFO (SyncWorker_5) [supervisor.docker.interface] Stop homeassistant application
20-05-22 18:38:29 INFO (SyncWorker_5) [supervisor.docker.interface] Clean homeassistant application
20-05-22 18:38:29 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-05-22 18:38:30 INFO (SyncWorker_6) [supervisor.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.110.1
20-05-22 18:39:05 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-05-22 18:39:50 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-05-22 18:39:55 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-05-22 18:45:17 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-05-22 18:55:20 WARNING (MainThread) [supervisor.homeassistant] Don’t wait anymore of Home Assistant startup!
20-05-22 18:55:20 CRITICAL (MainThread) [supervisor.homeassistant] HomeAssistant update fails -> rollback!
