w00zy
(w00zy)
1 Agosto , 2023 03:43
1
Tenho vindo a flashar alguns equipamentos Over-the-Air com o tuya-cloudcutter
Hoje flashei um termostato com ESPHome
LibreTiny ESPHome yaml
# BHT-006GBW Thermostat
esphome:
friendly_name: Thermostat
libretiny:
board: generic-bk7231n-qfn32-tuya
framework:
version: dev
logger:
baud_rate: 0
api:
ota:
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_password
ap:
captive_portal:
web_server:
uart:
rx_pin: P10
tx_pin: P11
baud_rate: 9600
time:
- platform: homeassistant
tuya:
time_id: ha_time
climate:
- platform: tuya
switch_datapoint: 1
target_temperature_datapoint: 16
current_temperature_datapoint: 24
active_state_datapoint: 3
active_state_heating_value: 0
eco_datapoint: 4
eco_temperature: 20 °C
temperature_multiplier: 0.1
visual:
min_temperature: 10 °C
max_temperature: 30 °C
temperature_step: 0.5 °C
- platform: tuya
device_class: "temperature"
sensor_datapoint: 24
unit_of_measurement: "°C"
accuracy_decimals: 1
filters:
- multiply: 0.1
- platform: tuya
name: "Temperatura Sensor Externo"
sensor_datapoint: 101
filters:
- multiply: 0.1
switch:
- platform: tuya
name: "Modo Económico"
icon: mdi:leaf
switch_datapoint: 4
- platform: tuya
icon: mdi:lock
switch_datapoint: 40
select:
- platform: tuya
enum_datapoint: 2
options:
0: Agendamento
1: Manual
- platform: tuya
name: "Sensor Temperatura"
enum_datapoint: 102
options:
0: Interno
2: Externo
1: Interno e Externo
w00zy
(w00zy)
1 Agosto , 2023 03:59
2
Estas lâmpadas tambem foram flashadas Over-the-Air mas desta vez usei o firmware OpenBeken que é muito semelhante ao Tasmota
Obrigado pela partilha já tinha ouvido falada desse firmware mas desconhecia ser semelhante ao tasmota.
diogopms
(Diogo)
12 Outubro , 2023 13:17
4
Venho aqui deixar o feedback no Tuya Smart IR
Link: https://www.aliexpress.com/item/1005003741171217.html
Exploit usado Cloud-tuya-cutter: 2.0.0 - BK7231N / oem_bk7231n_irbox_mol_ty
Configuração esphome específica do dispositivo:
substitutions:
hostname: esp-tuya-ir
esphome:
bk72xx:
board: cb3s
# falta wifi....secret etc.
remote_transmitter:
pin: P26
carrier_duty_percent: 50%
remote_receiver:
pin:
number: P7
mode: INPUT_PULLUP
inverted: true
dump: all
output:
- platform: libretiny_pwm
pin: P8
frequency: 1000 Hz
light:
- platform: monochromatic
output: pwm_output
name: "IR Status Light"
binary_sensor:
- platform: gpio
pin:
number: P6
mode:
input: true
pullup: true
inverted: true
switch:
turn_on_action:
- remote_transmitter.transmit_samsung:
data: 0xE0E040BF
pplucky
(Pplucky)
12 Outubro , 2023 14:21
5
Feedback da sirene Blitzwolf BW-IS11
Link: https://www.blitzwolfeurope.com/BlitzWolf-BW-IS11-Wi-Fi-Smart-Siren-Alarm-90dB
Exploit usado Cloud-tuya-cutter: bk7231t-common-user-config-ty-1.1.71-sdk-1.0.2-40.00
# Disable logging via UART, we need it for the Tuya MCU
logger:
baud_rate: 0
# Becken Wifi chip WB3S/BK7231T - https://developer.tuya.com/en/docs/iot/wb3s-module-datasheet?id=K9dx20n6hz5n4
# Connected pins to board: TXD1/RXD1/RXD2/TXD2/PWM1 and GND on one side, VCC on the other
# TXD1 and RXD1 are connected to Tuya MCU as per below UART defined connection
# LibreTiny board identification
bk72xx:
board: wb3s
# Tuya MCU identified as HC32F003C4PA (https://jlcpcb.com/partdetail/XHSC-HC32F003C4PATSSOP20TR/C784649)
# Initialize the UART that connects to the Tuya MCU (via TXD1 and RXD1)
uart:
rx_pin: P10
tx_pin: P11
baud_rate: 9600
# Register the Tuya MCU connection (https://esphome.io/components/tuya)
tuya:
# Siren State in form of problem binary sensor (similar to LocalTuya)
binary_sensor:
- platform: "template"
device_class: problem
icon: mdi:alarm-light
lambda: |-
if ( id(select_siren_mode).state == "Off" ) {
return false;
} else if ( id(select_siren_mode).state != "" ) {
return true;
} else {
return {};
# Siren Operation Mode (as in TuyaIOT platform)
# https://developer.tuya.com/en/docs/iot/f?id=K9gf47snd3n03
select:
- platform: tuya
enum_datapoint: 1
optimistic: true
options:
3: "Off" #normal
1: "Light" #alarm_light
0: "Sound" #alarm_sound
2: "Sound + Light" #alarm_sound_light
# Siren Muffling/Mute (as in TuyaIOT platform)
switch:
- platform: "tuya"
switch_datapoint: 16
