Boa tarde a todos.
Depois de ter tido um problema no servidor ( o mac tentou forçar uma actualização, e fez com que a máquina virtual que corre o HA parasse), ao tentar aceder à máquina virtual o VirtualBox crachou e fechou. Voltei a abrir e a inicar mas agora o HA entra em SafeMode e não consigo resolver. Preciso da vossa ajuda novamente…
tenho estes erros no log:
Logger: homeassistant.components.webhook
Source: components/webhook/__init__.py:84
Integration: Webhook (documentation, issues)
First occurred: 12:57:19 (92 occurrences)
Last logged: 19:27:04
Received message for unregistered webhook 0954229700620baa6b9f7b4d3b8456f04c45fe54e1e9881af4412bad3aaa32f3 from 213.228.137.19
Received message for unregistered webhook 0954229700620baa6b9f7b4d3b8456f04c45fe54e1e9881af4412bad3aaa32f3 from 213.228.168.250
Received message for unregistered webhook 0954229700620baa6b9f7b4d3b8456f04c45fe54e1e9881af4412bad3aaa32f3 from 2.81.141.172
Logger: homeassistant.components.hassio
Source: components/hassio/__init__.py:407
Integration: Hass.io (documentation, issues)
First occurred: 18:39:56 (1 occurrences)
Last logged: 18:39:56
Invalid config for [http]: not a file for dictionary value @ data['http']['ssl_certificate']. Got '/ssl/fullchain.pem' not a file for dictionary value @ data['http']['ssl_key']. Got '/ssl/privkey.pem'. (See /config/configuration.yaml, line 15).
Logger: aiohttp.server
Source: /usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py:393
First occurred: 12:48:46 (13 occurrences)
Last logged: 18:34:49
Error handling request
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 314, in data_received
messages, upgraded, tail = self._request_parser.feed_data(data)
File "aiohttp/_http_parser.pyx", line 546, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message="Bad status line 'invalid HTTP method'"
Obrigada a todos pela ajuda.
