Boa noite a todos,
Estive a seguir o tutorial " Como configurar o zigbee2mqtt em Hassio com uma CC2531" mas acontece apôs a reiniciar o Raspberry não me aparece o menu do passo 3 .
Podem me dar uma ajuda?
obrigado
Boa noite a todos,
obrigado
mostra lá o que colocaste no package sff @imrr
@imrr para emparelhar os devices podes evitar esses passos bastando por na tua configuração algo similar a esta (onde está em amarelo)
default_config:
# http:
# Text to speech
tts:
- platform: google_translate
mqtt:
broker: 192.168.1.48
port: 1883
client_id: hassio
keepalive: 60
username: mosquitto
password: mosquitto
discovery: true
input_boolean:
zigbee_permit_join:
name: Allow devices to join
initial: off
icon: mdi:cellphone-wireless
timer:
zigbee_permit_join:
name: Time remaining
duration: 600 # Updated this to the number of seconds you wish
state_topic: "zigbee2mqtt/bridge/state"
icon: mdi:router-wireless
group:
zigbee_group:
- input_boolean.zigbee_permit_join
- timer.zigbee_permit_join
- sensor.bridge_state
automation:
- id: enable_zigbee_join
alias: Enable Zigbee joining
hide_entity: true
platform: state
entity_id: input_boolean.zigbee_permit_join
to: 'on'
- service: mqtt.publish
topic: zigbee2mqtt/bridge/config/permit_join
payload: 'true'
- service: timer.start
entity_id: timer.zigbee_permit_join
- id: disable_zigbee_join
alias: Disable Zigbee joining
- entity_id: input_boolean.zigbee_permit_join
platform: state
to: 'off'
- data:
payload: 'false'
- data:
service: timer.cancel
hide_entity: true
- id: disable_zigbee_join_timer
alias: Disable Zigbee joining by timer
hide_entity: true
- platform: event
event_type: timer.finished
event_data:
payload: 'false'
entity_id: input_boolean.zigbee_permit_joindigite ou cole aqui o código
Por acaso já tinha experimentado como dizes
"data_path": "/share/zigbee2mqtt",
"devices": "devices.yaml",
"groups": "groups.yaml",
"homeassistant": true,
"permit_join": true,
"mqtt": {
"base_topic": "zigbee2mqtt",
"server": "mqtt://192.168.1.48",
"user": "mosquitto",
"password": "mosquitto"
"serial": {
"port": "/dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B0019365C77-if00"
"advanced": {
"pan_id": 6754,
"channel": 11,
"network_key": [
1,
3,
5,
7,
9,
11,
13,
15,
0,
2,
4,
6,
8,
10,
12,
13
"availability_blacklist": []
"ban": [],
"whitelist": [],
"queue": {},
"socat": {
"enabled": false,
"master": "pty,raw,echo=0,link=/dev/ttyZ2M,mode=777",
"slave": "tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5",
"restartdelay": 1,
"initialdelay": 1,
"options": "-d -d",
"log": false
Boa noite,
Não estou a conseguir não sei mais que posso fazer, já fiz vários tutoriais e nada.
Têm mais sugestões que possam ajudar?
obrigado
Posso não ter compreendido bem a situação, mas sabes que depois de instalar o zigbee2mqtt e colocar o código no configuration.yaml ou em packages, é preciso configurar o lovelace para aparecer o input_boolean e o timer, certo?
Vamos por partes:
O addon arranca sem erros? Faz start, espera 1 minuto e depois no log (dentro do addon) carrega em ‘refresh’ e mostra o que aparece.
E será que a pen é mesmo uma CC2531ou é uma CC2540?
Pois isso já não sei eu comprei aqui no forum a um utilizador.
Vou pesquisar como posso ver o tipo.
Basta ver o chip, tem lá escrito a referência. Já tem acontecido, inclusive a mim, enviarem uma CC2540 que é exactamente igual e aceita o mesmo firmware mas é bluetooth.
Boas, aqui vai o codigo:
Log
./run.sh: line 16: [Info] Configuration backup found in /share/zigbee2mqtt/.configuration.yaml.bk. Skipping config backup.: No such file or directory
[Info] Socat is DISABLED and not started
2019-12-17T22:06:32: PM2 log: Launching in no daemon mode
2019-12-17T22:06:33: PM2 log: App [npm:0] starting in -fork mode-
2019-12-17T22:06:33: PM2 log: App [npm:0] online
> [email protected] start /zigbee2mqtt-1.8.0
> node index.js
zigbee2mqtt:info 2019-12-17 22:06:48: Logging to console and directory: '/share/zigbee2mqtt/log/2019-12-17.22-06-47'
zigbee2mqtt:info 2019-12-17 22:06:50: Starting zigbee2mqtt version 1.8.0 (commit #unknown)
zigbee2mqtt:info 2019-12-17 22:06:50: Starting zigbee-herdsman...
zigbee2mqtt:info 2019-12-17 22:06:53: zigbee-herdsman started
zigbee2mqtt:info 2019-12-17 22:06:53: Coordinator firmware version: '{"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190223}}'
zigbee2mqtt:info 2019-12-17 22:06:53: Currently 0 devices are joined:
zigbee2mqtt:warn 2019-12-17 22:06:53: `permit_join` set to `true` in configuration.yaml.
zigbee2mqtt:warn 2019-12-17 22:06:53: Allowing new devices to join.
zigbee2mqtt:warn 2019-12-17 22:06:53: Set `permit_join` to `false` once you joined all devices.
zigbee2mqtt:info 2019-12-17 22:06:53: Zigbee: allowing new devices to join.
zigbee2mqtt:info 2019-12-17 22:06:53: Connecting to MQTT server at mqtt://192.168.1.48
zigbee2mqtt:info 2019-12-17 22:06:58: Connected to MQTT server
zigbee2mqtt:info 2019-12-17 22:06:58: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
zigbee2mqtt:info 2019-12-17 22:06:58: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"version":"1.8.0","commit":"unknown","coordinator":{"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":6,"maintrel":3,"revision":20190223}},"log_level":"info","permit_join":true}'
Já confirmei é CC2531.
Aparentemente o addon está a funcionar. Agora só tens de emparelhar os equipamentos com o CC2531. Depois tens de executar o procedimento de emparelhamento para cada dispositivo.
Os dispositivos no momento de emparelhamento devem estar relativamente proximos do CC2531. Outra coisa, o CC2531 não deve estar muito próximo de outro emissor radio, ou seja, WIFI, Z-wave etc…
Que dispositivos estás a tentar adicionar?
Z-Wave não trabalha na mesma frequência do zigbee, o Wi-fi sim
Apenas para complementar o que o @ricreis394 disse:
Eu sempre li que para emparelhar devemos colocar os dispositivos próximos do CC2531 ou de um router zigbee.
Mas sempre emparelhei os dispositivos logo no local onde os quero deixar e sempre funcionou.
Acredito que possam demorar um pouco mais do que se estiverem perto do coordinator/router, mas nunca tive problemas a emparelhar.
Sensores humidade e temperatura Aqara.
@imrr já conseguiste resolver o problema?
CPHA.pt - [email protected]
