Problema a configurar zigbee2mqtt
Boas malta, estou com problemas a tentar configurar o zigbee2mqtt.
tenho a seguinte configuração:
data_path: /share/zigbee2mqtt
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
  base_topic: zigbee2mqtt
  server: 'mqtt://192.168.1.xxx'
  user: xxxxxxxxx
  password: xxxxxxx
serial:
  port: /dev/ttyAMA0
advanced:
  pan_id: 6754
  channel: 11
  report: true
  network_key:
    - 1
    - 3
    - 5
    - 7
    - 9
    - 11
    - 13
    - 15
    - 0
    - 2
    - 4
    - 6
    - 8
    - 10
    - 12
    - 13
  availability_blacklist: []
ban: []
whitelist: []
queue: {}
socat:
  enabled: false
  master: 'pty,raw,echo=0,link=/dev/ttyZ2M,mode=777'
  slave: 'tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5'
  restartdelay: 1
  initialdelay: 1
  options: '-d -d'
  log: false
e depois no log do addon tenho erros que não sei como posso resolver.
./run.sh: line 17: [Info] Configuration backup found in /share/zigbee2mqtt/.configuration.yaml.bk. Skipping config backup.: No such file or directory
[Info] Socat is DISABLED and not started
2020-02-25T23:17:23: PM2 log: Launching in no daemon mode
2020-02-25T23:17:23: PM2 log: App [npm:0] starting in -fork mode-
2020-02-25T23:17:23: PM2 log: App [npm:0] online
> [email protected] start /zigbee2mqtt-1.10.0
> node index.js
zigbee2mqtt:info  2020-02-25 23:17:26: Logging to console and directory: '/share/zigbee2mqtt/log/2020-02-25.23-17-26' filename: log.txt
zigbee2mqtt:info  2020-02-25 23:17:26: Starting zigbee2mqtt version 1.10.0 (commit #unknown)
zigbee2mqtt:info  2020-02-25 23:17:26: Starting zigbee-herdsman...
zigbee2mqtt:error 2020-02-25 23:18:15: Error while starting zigbee-herdsman
zigbee2mqtt:error 2020-02-25 23:18:15: Failed to start zigbee
zigbee2mqtt:error 2020-02-25 23:18:15: Exiting...
zigbee2mqtt:error 2020-02-25 23:18:15: Error: AREQ - SYS - resetInd after 30000ms
    at Timeout._onTimeout (/zigbee2mqtt-1.10.0/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
    at listOnTimeout (internal/timers.js:531:17)
    at processTimers (internal/timers.js:475:7)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
Será que alguem me ode dar uma ajuda?
Antes de mais uma pergunta que poderá parecer parva: tens a certeza que é um CC2531? Se puderes coloca uma foto do chip.
Sim é CC531 mas logo já coloco foto da mesma.
ok, experimenta desligar o CC 2531 com o addon parado, voltas a ligar a pen e o addon e vê se funciona.
Esse erro que mostras é típico de quando se liga um CC2540 ou similar mas poderá ser outro o problema. Tens o ultimo firmware flashado?
Já agora só para tentar ajudar e comparando com o meu:
a serial_port é mesmo essa? tenho a minha assim
serial:
  port: /dev/ttyACM0
e acho que é a maioria dos casos.
Na linha do server também tenho assim:
  server: 'mqtt://core-mosquitto'
mas aí a tua configuração também parece correcta.
A pen foi flashada por mim. Mas também começo a desconfiar que não ficou bem. Se calhar vai ser melhor fazer o flash de novo. :thinking:
@maxcalavera vou tentar fazer o que o @j_assuncao disse depois dou feedback, caso contrario envio para ti novamente, já que na minha zona não tenho ninguém que a flash .
É mesmo a cc2531
:+1:
Ainda bem que é. Os relatos de pens CC2531 que são enviadas enganadas são cada vez mais.
Dá erro na mesma, vou enviar a pen ao amigo Bruno
