Lovelace com diferentes apresentações
Vivam!
Tenho o Hassio instalado num raspberry pi e, como estou a configurá-lo ando com ele na mala.
Quando no trabalho o ligo directamente à internet tenho esta cara
Quando o ligo em casa onde tenho um router da Mikrotik tem esta cara
Alguem me consegue dar uma pista do que poderá ser?
Há algum log do lovelace onde possa ter pistas do que acontece?
  title: My Awesome Home
# Include external resources
resources:
#  - url: /local/my-custom-card.js
#    type: js
#  - url: /local/my-webfont.css
#    type: css
  - url: /local/gauge-card.js?v=1
    type: js
#  - url: /local/weather-card.js
#    type: js
  - url: /local/vertical-stack-in-card.js?v=0.0.2
    type: js
#  - url: /local/mycard.js
#    type: js
# Optional background for all views. Check https://developer.mozilla.org/en-US/docs/Web/CSS/background for more examples.
#background: center / cover no-repeat url("/background.png") fixed
# Exclude entities from "Unused entities" view
excluded_entities:
  - weblink.router
     # View my tab.
  - icon: mdi:home-circle
    title: Home
    # Optional unique id for direct access /lovelace/${id}
    # Optional background (overwrites the global background).
    #background: radial-gradient(crimson, skyblue)
    # Each view can have a different theme applied. Theme should be defined in the frontend.
    theme: dark-mode
    # The cards to show on this view.
    cards:
#     - type: "mycard"
#       entity: light.garagem_luz_tv
     - type: entities
         - group.casa
         - group.piscina
      # The picture entity card will represent an entity with a picture
     - type: custom:gauge-card
       title: Temperature
       entity: sensor.random_temperature
       min: -20
       max: 35
     - type: entities
         - light.luz_sala
     - type: picture-entity
       image: /local/img/mobile1.jpg
       entity: switch.Bedroom Switch
  - icon: mdi:swim
    title: Piscina
    cards:
      - type: vertical-stack
#      - type: vertical-stack-in-card
        cards:
          - type: markdown
            title: Piscina
            content: >
#                 Welcome to your **Lovelace UI**.
          - type: entities
              - switch.motor_piscina
              - light.luz_piscina
                title: Temperatura agua piscina
                entity: sensor.pool_water
                min: 0
                max: 30
                title: Temperatura casa bomba
                entity: sensor.pool_room
                min: -5
                max: 50
                title: Temperatura bomba
                entity: sensor.pool_pump
                min: -5
                max: 70
  - icon: car-side
    title: Garagem
    cards:
      # The markdown card will render markdown text.
      - type: markdown
        title: Garagem
        content: >
      - type: entities
          - switch.interruptor_garagem
          - light.garagem_luz_tv
#      - type: custom:gauge-card
#        title: Temperatura agua piscina
#        entity: sensor.pool_water
#        min: 0
#        max: 30
  - icon: mdi:network
    title: Devices
    # defined in the frontend.
    theme: dark-mode
    cards:
        cards:
          - type: markdown
            title: Network
            content: >
          - type: entities
              - light.luz_piscina
              - light.luz_sala
              - switch.bedroom_switch
                min: -20
                max: 35
    # Specify a tab icon if you want the view tab to be an icon.
#  - icon: mdi:weather-cloudy
#    # Optional unique id for direct access /lovelace/${id}
#    id: Weather
#    title: Weather
#    cards:
#      - type: 'custom:custom-weather-animated'
#        entity: input_boolean.weather
#    # View tab title.
#  - title: Example
#    id: example
#    # Optional background (overwrites the global background).
#    background: radial-gradient(crimson, skyblue)
#    # Each view can have a different theme applied. Theme should be defined in the frontend.
#    theme: dark-mode
#    # The cards to show on this view.
#    cards:
#        # The filter card will filter entities for their state
#      - type: entity-filter
#        entities:
#          - device_tracker.paulus
#          - device_tracker.anne_there
#        state_filter:
#          - 'home'
#        card:
#          type: glance
#          image: https://www.home-assistant.io/images/default-social.png
#          title: People that are home
#        # The picture entity card will represent an entity with a picture
#      - type: picture-entity
#        entity: light.luz_piscina
#    # Specify a tab icon if you want the view tab to be an icon.
#  - icon: mdi:zodiac-taurus
#    title: test view
#    cards:
#     - type: entities
#       entities:
#         - light.luz_piscina
  - icon: mdi:home-assistant
    # Title of the view. Will be used as the tooltip for tab icon
    title: Second view
    cards:
        # Entities card will take a list of entities and show their state.
      - type: entities
        # Title of the entities card
        title: Example
        # The entities here will be shown in the same order as specified.
        # Each entry is an entity ID or a map with extra options.
          - light.luz_piscina
          - light.luz_sala
          - entity: switch.motor_piscina
            # Override the name to use
      - type: markdown
        title: Lovelace
        content: >
O que acontece é que estás a utilizar dois PCs diferentes para aceder ao Rpi e falta definir num deles que queres utilizar o Lovelace como interface.
Essa opção funciona por cookie e não por utilizador.
E como faço para definir que quero o “lovelace como interface” isso?
Da mesma maneira que fizeste para o outro browser que tem o Lovelace configurado como interface…
Boas. Tal como o @j_assuncao disse, tem a haver com a interface. Tás a usar duas interfaces diferentes. Em cada dispositivo, se quiseres o lovelace, tens que carregar no botão do menu (3 barras horizontais no canto superior esquerdo), depois carregas no icon de informação (um círculo com a letra “i” dentro) e depois aparece uma opcao que diz “set lovelace as default on this device” ou algo do genero. E so carregares, e pronto :wink: Basta entrares de novo e já está com o lovelace
Já não me lembrava de ter feito isto.
