Instalaçao do HASS em MAC
Caros,
Estou com dificuldade em instalar o HA em MAC.
Ja instalei o phyton 3.9 do site original,
Abri o terminal e instalei o HA.
Quando executo o comando " hass --open-ui "
Para alem de nao abrir devolve a seguinte mensagem:
sera que ja esta instalado ?
onde posso ver o ip do mac para testar o endereço …8123 etc ?
iMac-de-Rui:~ ruiribeirodealmeida$ hass --open-ui
2021-01-02 12:52:30 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=30 from 2021-01-02 12:46:04.580084)
2021-01-02 12:52:35 ERROR (SyncWorker_3) [homeassistant.util.package] Unable to install package pillow==7.2.0: ERROR: Command errored out with exit status 1:
command: /Library/Frameworks/Python.framework/Versions/3.9/bin/python3.9 -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-_7qijna7/pillow/setup.py’"’"’; file=’"’"’/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-_7qijna7/pillow/setup.py’"’"’;f=getattr(tokenize, ‘"’"‘open’"’"’, open)(file);code=f.read().replace(’"’"’\r\n’"’"’, ‘"’"’\n’"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ install --record /private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-record-k3zjky5x/install-record.txt --single-version-externally-managed --prefix ‘’ --user --prefix= --compile --install-headers /Users/ruiribeirodealmeida/.homeassistant/deps/include/python3.9/pillow
cwd: /private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-_7qijna7/pillow/
Complete output (172 lines):
running install
running build
running build_py
creating build
creating build/lib.macosx-10.9-x86_64-3.9
creating build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/MpoImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageMode.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PngImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/XbmImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PcxImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/SunImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/SpiderImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/TarIO.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/FitsStubImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/MpegImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/BdfFontFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/GribStubImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageStat.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PixarImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/GimpPaletteFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageColor.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ContainerIO.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/MspImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/MicImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/_version.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImtImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/GifImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PalmImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageQt.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageMath.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PaletteFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/FontFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PdfParser.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ExifTags.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageCms.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/FpxImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageChops.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/BufrStubImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PSDraw.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PcdImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageFilter.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageDraw2.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImagePath.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/DcxImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/init.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/JpegPresets.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/Hdf5StubImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/features.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageDraw.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/GimpGradientFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageWin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/IcoImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/_tkinter_finder.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/EpsImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/TgaImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageMorph.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/Jpeg2KImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/WalImageFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PcfFontFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/BlpImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageTk.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/GbrImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageOps.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PdfImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageShow.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageEnhance.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/WmfImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageGrab.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/WebPImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/FliImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/TiffTags.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/CurImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/_util.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/GdImageFile.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/TiffImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/IptcImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImagePalette.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/BmpImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageTransform.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/IcnsImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/McIdasImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/XpmImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/DdsImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageSequence.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PyAccess.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/_binary.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/Image.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/main.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/XVThumbImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/SgiImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PsdImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/JpegImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/ImageFont.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/PpmImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
copying src/PIL/FtexImagePlugin.py -> build/lib.macosx-10.9-x86_64-3.9/PIL
running egg_info
writing src/Pillow.egg-info/PKG-INFO
writing dependency_links to src/Pillow.egg-info/dependency_links.txt
writing top-level names to src/Pillow.egg-info/top_level.txt
reading manifest file ‘src/Pillow.egg-info/SOURCES.txt’
reading manifest template ‘MANIFEST.in’
warning: no files found matching ‘.c’
warning: no files found matching '
.h’
warning: no files found matching ‘.sh’
warning: no previously-included files found matching ‘.appveyor.yml’
warning: no previously-included files found matching ‘.coveragerc’
warning: no previously-included files found matching ‘.editorconfig’
warning: no previously-included files found matching ‘.readthedocs.yml’
warning: no previously-included files found matching ‘codecov.yml’
warning: no previously-included files matching '.git
’ found anywhere in distribution
warning: no previously-included files matching ‘.pyc’ found anywhere in distribution
.so’ found anywhere in distribution
no previously-included directories found matching ‘.ci’
writing manifest file ‘src/Pillow.egg-info/SOURCES.txt’
running build_ext
The headers or library files could not be found for jpeg,
a required dependency when compiling Pillow from source.
Please see the install instructions at:
   https://pillow.readthedocs.io/en/latest/installation.html
  File "/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-_7qijna7/pillow/setup.py", line 864, in <module>
    setup(
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/setuptools/__init__.py", line 165, in setup
    return distutils.core.setup(**attrs)
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/core.py", line 148, in setup
    dist.run_commands()
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/dist.py", line 966, in run_commands
    self.run_command(cmd)
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/dist.py", line 985, in run_command
    cmd_obj.run()
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/site-packages/setuptools/command/install.py", line 61, in run
    return orig.install.run(self)
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/command/install.py", line 546, in run
    self.run_command('build')
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/cmd.py", line 313, in run_command
    self.distribution.run_command(command)
    cmd_obj.run()
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/command/build.py", line 135, in run
    self.run_command(cmd_name)
    cmd_obj.run()
  File "/Library/Frameworks/Python.framework/Versions/3.9/lib/python3.9/distutils/command/build_ext.py", line 340, in run
    self.build_extensions()
  File "/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-_7qijna7/pillow/setup.py", line 694, in build_extensions
    raise RequiredDependencyException(f)
__main__.RequiredDependencyException: jpeg
During handling of the above exception, another exception occurred:
  File "<string>", line 1, in <module>
  File "/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-_7qijna7/pillow/setup.py", line 918, in <module>
    raise RequiredDependencyException(msg)
ERROR: Command errored out with exit status 1: /Library/Frameworks/Python.framework/Versions/3.9/bin/python3.9 -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-_7qijna7/pillow/setup.py’"’"’; file=’"’"’/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-_7qijna7/pillow/setup.py’"’"’;f=getattr(tokenize, ‘"’"‘open’"’"’, open)(file);code=f.read().replace(’"’"’\r\n’"’"’, ‘"’"’\n’"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ install --record /private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-record-k3zjky5x/install-record.txt --single-version-externally-managed --prefix ‘’ --user --prefix= --compile --install-headers /Users/ruiribeirodealmeida/.homeassistant/deps/include/python3.9/pillow Check the logs for full command output.
WARNING: You are using pip version 20.2.3; however, version 20.3.3 is available.
You should consider upgrading via the ‘/Library/Frameworks/Python.framework/Versions/3.9/bin/python3.9 -m pip install --upgrade pip’ command.
2021-01-02 12:52:35 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Requirements for image not found: [‘pillow7.2.0’].
2021-01-02 12:52:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image
2021-01-02 12:52:35 ERROR (MainThread) [homeassistant.setup] Setup failed for person: Could not set up all dependencies.
2021-01-02 12:52:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: person
2021-01-02 12:52:35 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
2021-01-02 12:52:35 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: onboarding
2021-01-02 12:52:35 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2021-01-02 12:52:36 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of map. Setup failed for dependencies: frontend
2021-01-02 12:52:36 ERROR (MainThread) [homeassistant.setup] Setup failed for map: Could not set up all dependencies.
2021-01-02 12:52:36 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of logbook. Setup failed for dependencies: frontend
2021-01-02 12:52:36 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Could not set up all dependencies.
2021-01-02 12:52:36 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of mobile_app. Setup failed for dependencies: person
2021-01-02 12:52:36 ERROR (MainThread) [homeassistant.setup] Setup failed for mobile_app: Could not set up all dependencies.
2021-01-02 12:52:36 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of default_config. Setup failed for dependencies: frontend, logbook, map, mobile_app, person
2021-01-02 12:52:36 ERROR (MainThread) [homeassistant.setup] Setup failed for default_config: Could not set up all dependencies.
2021-01-02 12:52:36 WARNING (MainThread) [homeassistant.bootstrap] Detected that frontend did not load. Activating safe mode
2021-01-02 12:52:40 ERROR (SyncWorker_0) [homeassistant.util.package] Unable to install package pillow
command: /Library/Frameworks/Python.framework/Versions/3.9/bin/python3.9 -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-61etrcua/pillow/setup.py’"’"’; file=’"’"’/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-61etrcua/pillow/setup.py’"’"’;f=getattr(tokenize, ‘"’"‘open’"’"’, open)(file);code=f.read().replace(’"’"’\r\n’"’"’, ‘"’"’\n’"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ install --record /private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-record-wv1hvayk/install-record.txt --single-version-externally-managed --prefix ‘’ --user --prefix= --compile --install-headers /Users/ruiribeirodealmeida/.homeassistant/deps/include/python3.9/pillow
cwd: /private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-61etrcua/pillow/
running install
running build
running build_py
creating build
running egg_info
.h’
running build_ext
  File "/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-61etrcua/pillow/setup.py", line 864, in <module>
    setup(
    dist.run_commands()
    cmd_obj.run()
    cmd_obj.run()
    cmd_obj.run()
  File "/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-61etrcua/pillow/setup.py", line 694, in build_extensions
  File "/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-61etrcua/pillow/setup.py", line 918, in <module>
ERROR: Command errored out with exit status 1: /Library/Frameworks/Python.framework/Versions/3.9/bin/python3.9 -u -c ‘import sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-61etrcua/pillow/setup.py’"’"’; file=’"’"’/private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-install-61etrcua/pillow/setup.py’"’"’;f=getattr(tokenize, ‘"’"‘open’"’"’, open)(file);code=f.read().replace(’"’"’\r\n’"’"’, ‘"’"’\n’"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ install --record /private/var/folders/pr/6rwyrr9j4nx7hq5v1yc1x2n00000gn/T/pip-record-wv1hvayk/install-record.txt --single-version-externally-managed --prefix ‘’ --user --prefix= --compile --install-headers /Users/ruiribeirodealmeida/.homeassistant/deps/include/python3.9/pillow Check the logs for full command output.
2021-01-02 12:52:40 ERROR (MainThread) [homeassistant.setup] Setup failed for image: Requirements for image not found: [‘pillow==7.2.0’].
2021-01-02 12:52:40 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of person. Setup failed for dependencies: image
2021-01-02 12:52:40 ERROR (MainThread) [homeassistant.setup] Setup failed for person: Could not set up all dependencies.
2021-01-02 12:52:40 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of onboarding. Setup failed for dependencies: person
2021-01-02 12:52:40 ERROR (MainThread) [homeassistant.setup] Setup failed for onboarding: Could not set up all dependencies.
2021-01-02 12:52:40 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of frontend. Setup failed for dependencies: onboarding
2021-01-02 12:52:40 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Could not set up all dependencies.
2021-01-02 12:52:40 ERROR (MainThread) [homeassistant.setup] Unable to set up dependencies of safe_mode. Setup failed for dependencies: frontend
2021-01-02 12:52:40 ERROR (MainThread) [homeassistant.setup] Setup failed for safe_mode: Could not set up all dependencies.
2021-01-02 12:52:40 ERROR (MainThread) [homeassistant.components.http] Failed to create HTTP server at port 8123: [Errno 48] error while attempting to bind on address (‘0.0.0.0’, 8123): address already in use
2021-01-02 12:52:40 WARNING (SyncWorker_3) [homeassistant.bootstrap] Cannot launch the UI because frontend not loaded
Olá benvido à CPHA, instalações em MAC está fora do meu conhecimento, consegues instalar Debian Buster? Se sim, exprimenta por aí.
É melhor usares o Docker, dessa forma vais perder muito mais tempo a instalar dependências e resolver problemas.
