Viva,
Estou com problemas em integrar os meus Shelly 1 no Home Assistant.
Tenho o broker a correr, os dispositivos aparecem na UI mas não consigo alterar o estado.
Plataforma:
- Win10
- Home Assistant a correr numa VM Hyper-V
- Versão do HA: 0.105.2
configuration.yml
default_config:
sun:
http:
base_url: https://xxxxxxxxxx:8123
ssl_key: /ssl/privkey.pem
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
light:
# Shelly
- platform: mqtt # TIPO: Luz
state_topic: "shellies/shelly1-C489A1/relay/0"
command_topic: "shellies/shelly1-C489A1/relay/0/command"
payload_on: "on"
payload_off: "off"
payload_available: "true"
payload_not_available: "false"
optimistic: false
qos: 0
retain: false
state_topic: "shellies/shelly1-C4849F/relay/0"
command_topic: "shellies/shelly1-C4849F/relay/0/command"
payload_on: "on"
payload_off: "off"
optimistic: false
qos: 0
retain: false
Configuração mosquitto:
logins: []
anonymous: false
customize:
active: false
folder: mosquitto
certfile: fullchain.pem
keyfile: privkey.pem
require_certificate: false
Log do mosquitto:
[21:03:39] INFO: Setup mosquitto configuration
[21:03:39] INFO: No local user available
[21:03:39] INFO: Initialize Hass.io Add-on services
[21:03:39] INFO: Initialize Home Assistant discovery
[21:03:39] INFO: Start Mosquitto daemon
1581282219: mosquitto version 1.6.3 starting
1581282219: Config loaded from /etc/mosquitto.conf.
1581282219: Loading plugin: /usr/share/mosquitto/auth-plug.so
1581282219: |-- *** auth-plug: startup
1581282219: ├── Username/password checking enabled.
1581282219: ├── TLS-PSK checking enabled.
1581282219: └── Extended authentication not enabled.
1581282219: Opening ipv4 listen socket on port 1883.
1581282219: Opening ipv6 listen socket on port 1883.
1581282219: Opening websockets listen socket on port 1884.
1581282220: Opening ipv4 listen socket on port 8883.
1581282220: Opening ipv6 listen socket on port 8883.
1581282220: Opening websockets listen socket on port 8884.
1581282220: Warning: Mosquitto should not be run as root/administrator.
1581282220: New connection from 172.30.32.1 on port 1883.
[INFO] found homeassistant on local database
1581282221: New client connected from 172.30.32.1 as auto-58EE19B8-14F0-47C7-8AD4-035DEB6DA1E8 (p2, c1, k60, u'homeassistant').
Configuração do Shelly:
IP: ip do HA
Clean
