Gostava da vossa ajuda para perceber o que está a causar o crash do meu container homeassistant (hassio) em Docker, este encontra-se na última versão.
Últimas ações alguma até revertidas mas sem qualquer impacto:
- update do Hassio
- update python package synology
- instalação do hacs
- Integrar PI-HOLE
- Intergrar Shelly for HACS
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 61, in load_yaml,
return yaml.load(conf_file, Loader=SafeLineLoader) or OrderedDict(),
File "/usr/local/lib/python3.8/site-packages/yaml/__init__.py", line 114, in load,
return loader.get_single_data(),
File "/usr/local/lib/python3.8/site-packages/yaml/constructor.py", line 51, in get_single_data,
return self.construct_document(node),
File "/usr/local/lib/python3.8/site-packages/yaml/constructor.py", line 55, in construct_document,
data = self.construct_object(node),
File "/usr/local/lib/python3.8/site-packages/yaml/constructor.py", line 100, in construct_object,
data = constructor(self, node),
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 192, in _ordered_dict,
nodes = loader.construct_pairs(node),
File "/usr/local/lib/python3.8/site-packages/yaml/constructor.py", line 154, in construct_pairs,
key = self.construct_object(key_node, deep=deep),
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 271, in secret_yaml,
secrets = _load_secret_yaml(secret_path),
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 248, in _load_secret_yaml,
secrets = load_yaml(secret_path),
File "/usr/local/lib/python3.8/site-packages/yaml/__init__.py", line 112, in load,
loader = Loader(stream),
File "/usr/local/lib/python3.8/site-packages/yaml/loader.py", line 34, in __init__,
Reader.__init__(self, stream),
File "/usr/local/lib/python3.8/site-packages/yaml/reader.py", line 85, in __init__,
self.determine_encoding(),
File "/usr/local/lib/python3.8/site-packages/yaml/reader.py", line 135, in determine_encoding,
self.update(1),
File "/usr/local/lib/python3.8/site-packages/yaml/reader.py", line 153, in update,
self.update_raw(),
File "/usr/local/lib/python3.8/site-packages/yaml/reader.py", line 178, in update_raw,
data = self.stream.read(size),
RecursionError: maximum recursion depth exceeded,
[cont-finish.d] executing container finish scripts...,
[cont-finish.d] done.,
[s6-finish] waiting for services.,
[s6-finish] sending all processes the TERM signal.,
[s6-finish] sending all processes the KILL signal and exiting.,
Posso colocar o resto dos log, mas parece-me que o erro final está neste RecursionError.
Vossa ajuda é muito bem vinda
