HA Docker @ Synology
Boa Dia comunidade :slight_smile:
Venho pedir-vos ajuda num dos meus problemas, neste caso o que mais constragimento tem causado na utilização do hass.io
O hass.io é uma docker a correr na minha Synology, sem razão aparente, pelo menos não entendo o porquê, fica inacessível com alguma frequência, diria pelo menos uma vez por dia tenho de reiniciar o container. Antes de voltar a fazê-lo neste momento, coloco o log que extraí para poderem analisar e opinar sobre possivel causa.
2020-04-10 06:46:05 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f25685fda10>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 07:34:03 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f25683dced0>: Failed to establish a new connection: [Errno -3] Try again')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 07:49:23 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 07:49:23 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 07:49:23 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 08:58:49 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2567f659d0>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 09:05:43 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 09:05:43 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 09:05:43 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 09:20:41 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2567e53e50>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 10:29:46 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'ConnectTimeoutError(<telegram.vendor.ptb_urllib3.urllib3.connectionpool.HTTPSConnectionPool object at 0x7f2579134090>, 'Connect timed out. (connect timeout=5.0)')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 10:38:59 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Heartbeat timeout, resetting connection,
2020-04-10 11:19:09 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 11:19:09 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 11:19:09 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 13:14:51 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'ConnectTimeoutError(<telegram.vendor.ptb_urllib3.urllib3.connectionpool.HTTPSConnectionPool object at 0x7f2579134090>, 'Connect timed out. (connect timeout=5.0)')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 14:19:45 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f256703bd90>: Failed to establish a new connection: [Errno -3] Try again')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 15:11:15 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f256775d2d0>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 15:24:08 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Heartbeat timeout, resetting connection,
2020-04-10 15:28:19 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Heartbeat timeout, resetting connection,
2020-04-10 15:31:17 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 15:31:18 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 15:31:18 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 16:51:24 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 16:51:24 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 16:51:24 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 17:07:44 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 17:07:45 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 17:07:45 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 17:13:12 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 17:13:12 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 17:13:12 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 17:16:45 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 17:16:45 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 17:16:45 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 17:17:44 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 17:17:44 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 17:17:44 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 17:39:45 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Heartbeat timeout, resetting connection,
2020-04-10 18:02:49 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 18:02:50 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 18:02:50 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 18:30:32 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f25664a8cd0>: Failed to establish a new connection: [Errno -3] Try again')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 18:37:28 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 18:37:28 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 18:37:28 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 18:39:02 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2566476110>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 18:51:45 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f25663899d0>: Failed to establish a new connection: [Errno -3] Try again')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 18:51:54 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Heartbeat timeout, resetting connection,
2020-04-10 18:52:02 WARNING (Thread-6) [pychromecast.socket_client] [Onkyo TX-NR686 EB602C:8009] Heartbeat timeout, resetting connection,
2020-04-10 19:08:47 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'ConnectTimeoutError(<telegram.vendor.ptb_urllib3.urllib3.connectionpool.HTTPSConnectionPool object at 0x7f2579134090>, 'Connect timed out. (connect timeout=5.0)')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 19:11:16 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 19:11:16 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 19:11:16 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 19:13:45 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 19:13:45 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 19:13:45 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 19:30:42 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Heartbeat timeout, resetting connection,
2020-04-10 19:51:41 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 19:51:42 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 19:51:42 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 20:43:20 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2565e51650>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 21:12:59 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2565ca8290>: Failed to establish a new connection: [Errno -3] Try again')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 21:21:32 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2565d3bb90>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 21:21:35 WARNING (Thread-6) [pychromecast.socket_client] [Onkyo TX-NR686 EB602C:8009] Heartbeat timeout, resetting connection,
2020-04-10 21:37:36 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 21:37:36 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 21:37:36 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 21:47:02 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2565b11090>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 21:59:44 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2565a067d0>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 22:08:51 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2565a06a90>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 22:34:57 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'ConnectTimeoutError(<telegram.vendor.ptb_urllib3.urllib3.connectionpool.HTTPSConnectionPool object at 0x7f2579134090>, 'Connect timed out. (connect timeout=5.0)')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 23:00:27 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f256578d690>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 23:00:36 WARNING (Thread-6) [pychromecast.socket_client] [Onkyo TX-NR686 EB602C:8009] Heartbeat timeout, resetting connection,
2020-04-10 23:04:53 WARNING (Thread-6) [pychromecast.socket_client] [Onkyo TX-NR686 EB602C:8009] Heartbeat timeout, resetting connection,
2020-04-10 23:14:06 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 23:14:06 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 23:14:06 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 23:16:50 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 23:16:50 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 23:16:50 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 23:17:34 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2565693d10>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 23:17:43 WARNING (Thread-6) [pychromecast.socket_client] [Onkyo TX-NR686 EB602C:8009] Heartbeat timeout, resetting connection,
2020-04-10 23:20:32 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 23:20:32 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 23:20:32 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 23:21:32 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 23:21:32 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 23:21:32 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 23:24:16 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-10 23:24:16 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-10 23:24:16 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-10 23:30:54 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f25655c9b50>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-10 23:56:20 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f25654e6fd0>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-11 00:15:25 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-11 00:15:26 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-11 00:15:26 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-11 00:55:44 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f256520e210>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-11 00:55:48 WARNING (Thread-6) [pychromecast.socket_client] [Onkyo TX-NR686 EB602C:8009] Heartbeat timeout, resetting connection,
2020-04-11 00:55:54 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None)) after connection broken by 'ConnectTimeoutError(<telegram.vendor.ptb_urllib3.urllib3.connectionpool.HTTPSConnectionPool object at 0x7f2579134090>, 'Connect timed out. (connect timeout=5.0)')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-11 00:58:11 WARNING (Thread-4) [websocket] send_ping routine terminated: [Errno 32] Broken pipe,
2020-04-11 01:42:33 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Heartbeat timeout, resetting connection,
2020-04-11 02:41:44 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'ConnectTimeoutError(<telegram.vendor.ptb_urllib3.urllib3.connectionpool.HTTPSConnectionPool object at 0x7f2579134090>, 'Connect timed out. (connect timeout=5.0)')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-11 02:50:57 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2564d48d10>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-11 02:50:57 WARNING (Thread-6) [pychromecast.socket_client] [Onkyo TX-NR686 EB602C:8009] Heartbeat timeout, resetting connection,
2020-04-11 02:51:04 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None)) after connection broken by 'ConnectTimeoutError(<telegram.vendor.ptb_urllib3.urllib3.connectionpool.HTTPSConnectionPool object at 0x7f2579134090>, 'Connect timed out. (connect timeout=5.0)')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-11 02:59:23 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2564cdb290>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-11 03:11:44 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-11 03:11:45 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-11 03:11:45 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-11 03:38:15 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2564bab050>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-11 03:42:39 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2564bf4b50>: Failed to establish a new connection: [Errno -3] Try again')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-11 03:42:40 WARNING (Thread-6) [pychromecast.socket_client] [Onkyo TX-NR686 EB602C:8009] Heartbeat timeout, resetting connection,
2020-04-11 04:58:51 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-11 04:58:51 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-11 04:58:51 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-11 05:46:21 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-11 05:46:21 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-11 05:46:21 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-11 06:16:28 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f25644a2550>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-11 06:21:23 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f256435fb10>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-11 06:42:32 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f25642f6f10>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-11 07:00:21 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Heartbeat timeout, resetting connection,
2020-04-11 07:25:05 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-11 07:25:05 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-11 07:25:05 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-11 09:24:52 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-11 09:24:53 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-11 09:24:53 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-11 10:07:32 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error reading from socket.,
2020-04-11 10:07:32 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Error communicating with socket, resetting connection,
2020-04-11 10:07:32 ERROR (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Failed to connect to service SHIELD-Android-TV-056c22a4ae9195697806b8aba9ba2b0f._googlecast._tcp.local., retrying in 5.0s,
2020-04-11 10:22:08 WARNING (updater) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x7f2563849c90>: Failed to establish a new connection: [Errno 101] Network unreachable')': /bot1079380255:AAED5PUfwy6eD-5SMpacEsUhFMwIkawW8wc/getUpdates,
2020-04-11 10:30:47 WARNING (Thread-7) [pychromecast.socket_client] [Living Room Shield TV:8009] Heartbeat timeout, resetting connection,
Na minha opinião, aparentemente até parece disponivel apresentando apenas alguns erros mas de ligação a dispositivos que nem sempre estão ligados, o caso da Nvidia Shield TV, e também erros de não ter terminado a configuração do telegram.
Qualquer opinião será bem vinda.
Abraços.
Olá Valter, conseguiu resolver esse problema ?
Ainda não, as falhas na ligação são esporádicas, 1x por dia diria, os erros que vejo são relacionados com algumas falhas de ligação a devices, não vejo algo especifico que seja a principal razão. Vou encontrar uma forma de partilhar o log, talvez assim possam ter mais informação que ajudem a identificar o problema.
