ESP32 CAM com ESPHOME, erro de autenticação ao visualizar imagens
Ola amigos. Instalei uma ESP32 CAM com ESPHOME. Toda ver que tento visualizar a imagem da câmera recebo o seguinte erro de autenticação:
Login attempt or request with invalid authentication from DESKTOP-5C60T60.Dlink (192.168.1.194). See the log for details.
Log com o erro:
Detalhes do log (ALERTA)
Logger: homeassistant.components.http.ban
Source: components/http/ban.py:124
Integration: HTTP ([documentation](https://www.home-assistant.io/integrations/http), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+http%22))
First occurred: 15:22:02 (5 occurrences)
Last logged: 16:48:21
Login attempt or request with invalid authentication from DESKTOP-5C60T60.Dlink (192.168.1.194). (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.110 Safari/537.36)
código ESPHOME da câmera:
esphome:
  platform: ESP32
  board: node32s
logger:
api:
ota:
  password: !secret senhaota
wifi:
  ssid: "Paulo_2G"
  password: !secret senhapaulo
  domain: .iot.local
  fast_connect: on
  manual_ip:
    static_ip: 192.168.1.195
    gateway: 192.168.1.1
    subnet: 255.255.255.0
    dns1: 192.168.1.1
  ap:
    ssid: "camera_saurom"
    password: "sf6Ec5w0UDSc"
captive_portal:
web_server:
esp32_camera:
  external_clock:
    pin: GPIO0
    frequency: 20MHz
  i2c_pins:
    sda: GPIO26
    scl: GPIO27
  data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
  vsync_pin: GPIO25
  href_pin: GPIO23
  pixel_clock_pin: GPIO22
  power_down_pin: GPIO32
  max_framerate: 5 fps    # default: 10 fps, max 60
  idle_framerate: 0.2 fps # default: 0.1 fps - framerate for 'picture' in HA dashboard
  resolution: 800x600     # default: 640x480 (VGA) - higher res requires more memory
  jpeg_quality: 10        # 10 (best) to 63 (worst)
  brightness : 2
switch:
  - platform: restart
    name: "Restart Camera Saurom"
binary_sensor:
  - platform: status
    name: "Status Camera Saurom"
  - platform: uptime
    name: Tempo atividade Camera Saurom
  - platform: wifi_signal
    name: "Sinal Wi-Fi Camera Saurom"
    update_interval: 60s
text_sensor:
  - platform: version
    name: "Versão Camera Saurom"
    name: "Camera Saurom - Uptime"
    lambda: |-
      int seconds = (id(tempo_atividade_camera_saurom).state);
      int days = seconds / (24 * 3600);
      seconds = seconds % (24 * 3600);
      int hours = seconds / 3600;
      seconds = seconds % 3600;
      int minutes = seconds /  60;
      seconds = seconds % 60;
      return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
    icon: mdi:clock-start
    update_interval: 70s
# ligar Luz na gpio4 e depois liberar o código
output:
  - platform: gpio
    pin: GPIO4
light:
  - platform: binary
    output: gpio_4
    name: Camera Saurom light
Atualizando a página a imagem chega a aparecer mas depois de alguns segundos ela some e o erro reaparece.
Alguém pode dar uma luz?
Verifica se as credenciais de acesso estão corretas e se o ip não está bloqueado.
Onde verifico estas informações?
verifica se tens uma file no config folder ip_bans.yaml com o ip banido la dentro
Não tem, então o ip não esta banido certo? Agora, onde verifico as credenciais?
As credenciais estão no código que tens acima.
Estão corretas sim. A imagem da câmera pode ser vista por alguns segundos antes que desapareça e receba a mensagem de erro de autenticação.
