Boa tarde a todos.
Atualizei o meu HA Supervisor para a última versão supervisor-2021.03.3 e agora recebo nas notificações 2 mensagens
Insecure secrets in core_samba
The add-on core_samba uses secrets which are detected as not secure, see https://www.home-assistant.io/more-info/pwned-passwords for more information.
Insecure secrets in core_mosquitto
The add-on core_mosquitto uses secrets which are detected as not secure, see https://www.home-assistant.io/more-info/pwned-passwords for more information.
Pelo que li, está relacionado com a password.
Mas as passwords são diferentes. Se a do MQTT é fraca, a o SAMBA já não é!
No log, também comecei a receber um erro do MQTT
Logger: homeassistant.components.mqtt.cover
Source: components/mqtt/cover.py:322
Integration: MQTT (documentation, issues)
First occurred: 0:06:13 (801 occurrences)
Last logged: 13:18:09
Payload is not supported (e.g. open, closed, opening, closing, stopped): {“Time”:“2021-03-04T13:13:48”,“Uptime”:“0T13:10:09”,“UptimeSec”:47409,“Heap”:27,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:1,“POWER1”:“OFF”,“POWER2”:“OFF”,“Wifi”:{“AP”:2,“SSId”:“HomeSweetHome”,“BSSId”:“CC:19:A8:2D:7E:80”,“Channel”:6,“RSSI”:88,“Signal”:-56,“LinkCount”:1,“Downtime”:“0T00:00:03”}}
Payload is not supported (e.g. open, closed, opening, closing, stopped): {“Time”:“2021-03-04T13:16:14”,“Uptime”:“0T13:15:10”,“UptimeSec”:47710,“Heap”:27,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:1,“POWER1”:“OFF”,“POWER2”:“OFF”,“Wifi”:{“AP”:2,“SSId”:“HomeSweetHome”,“BSSId”:“CC:19:A8:2D:7E:80”,“Channel”:6,“RSSI”:68,“Signal”:-66,“LinkCount”:1,“Downtime”:“0T00:00:03”}}
Payload is not supported (e.g. open, closed, opening, closing, stopped): {“Time”:“2021-03-04T13:16:57”,“Uptime”:“0T13:15:09”,“UptimeSec”:47709,“Heap”:27,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:1,“POWER1”:“OFF”,“POWER2”:“OFF”,“Wifi”:{“AP”:2,“SSId”:“HomeSweetHome”,“BSSId”:“CC:19:A8:2D:7E:80”,“Channel”:6,“RSSI”:58,“Signal”:-71,“LinkCount”:1,“Downtime”:“0T00:00:03”}}
Payload is not supported (e.g. open, closed, opening, closing, stopped): {“Time”:“2021-03-04T13:17:31”,“Uptime”:“0T13:15:09”,“UptimeSec”:47709,“Heap”:27,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:1,“POWER1”:“OFF”,“POWER2”:“OFF”,“Wifi”:{“AP”:2,“SSId”:“HomeSweetHome”,“BSSId”:“CC:19:A8:2D:7E:80”,“Channel”:6,“RSSI”:40,“Signal”:-80,“LinkCount”:1,“Downtime”:“0T00:00:03”}}
Payload is not supported (e.g. open, closed, opening, closing, stopped): {“Time”:“2021-03-04T14:18:09”,“Uptime”:“0T13:15:09”,“UptimeSec”:47709,“Heap”:27,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“MqttCount”:1,“POWER1”:“OFF”,“POWER2”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“HomeSweetHome”,“BSSId”:“CC:19:A8:2D:7E:80”,“Channel”:6,“RSSI”:64,“Signal”:-68,“LinkCount”:1,“Downtime”:“0T00:00:03”}}
Se alguém puder ajudar agradeço.
Tenho também um erro do bot do telegram, mas primeiro queria resolver estes.
