Antes de mais sou novato no Home Assistant, mas andava todo contente pois antes de fazer o upgrade do HA tinha tudo a funcionar.
Após o upgrade verifiquei que não tinha acesso aos sonoff e que o telegram tinha deixado de enviar as notificações.
Instalei o add-on “Check Home Assistant configuration” e aparecem estes erros, peço desde já desculpa por vos chatear com algo que possivelmente será basico, mas que eu não consigo ultrapassar.
WARNING: You are using pip version 19.1.1, however version 19.2.1 is available. You should consider upgrading via the ‘pip install --upgrade pip’ command.
INFO:homeassistant.util.package:Attempting install of colorlog4.0.2 Testing configuration at /tmp/config INFO:homeassistant.util.package:Attempting install of netdisco2.6.0 INFO:homeassistant.util.package:Attempting install of home-assistant-frontend20190805.0 INFO:homeassistant.util.package:Attempting install of libpyfoscam1.0 INFO:homeassistant.util.package:Attempting install of PyXiaomiGateway0.12.3 INFO:homeassistant.util.package:Attempting install of mutagen1.42.0 INFO:homeassistant.util.package:Attempting install of gTTS-token1.1.3 INFO:homeassistant.util.package:Attempting install of python-telegram-bot11.1.0 Failed config General
Errors:
Integration not found: sonoff Successful config (partial)
