Erro validar HA
Ao validar está-me a dar este erro, pela identificação na linha tem a ver com automation: !include automations.yaml, como não andei a alterar o configuration, penso que o erro começou após o update
Invalid config for [automation]: [data] is an invalid option for [automation]. Check: automation->action->0->data. (See /config/configuration.yaml, line 101). Please check the docs at https://home-assistant.io/components/automation/
homeassistant:
  name: Casa Pedro Oliveira
  latitude: !secret home_latitude
  longitude: !secret home_longitude
  elevation: 6
  unit_system: metric
  time_zone: Europe/Lisbon
  # Customization file
#introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  # Secrets are defined in the file secrets.yaml
  base_url: !secret http_password
  server_port: !secret server_port
  api_password: !secret http_password
  ssl_key: /ssl/privkey.pem
  #ip_ban_enabled: True
  #login_attempts_threshold: 3
# the developers to assist with development of Home Assistant.
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/0u??+
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
   include_used_components: true
# discovery:
  # ignore:
    # - plex
#conversation:
# Enables support for tracking state changes over time
history:
  include:
      - sensor.temperature_158d00011739b9
      - sensor.humidity_158d00011739b9
      - binary_sensor.motion_sensor_158d000272bd55
      - switch.plug_158d0001dc9be5
      - switch.plug_158d00010dde01
      - switch.plug_158d0001dad4ed
# logbook:
  # include:
    # entities:
      # - sensor.temperature_158d00011739b9
      # - sensor.humidity_158d00011739b9
      # - binary_sensor.motion_sensor_158d000272bd55
      # - switch.plug_158d0001dc9be5
      # - switch.plug_158d00010dde01
      # - switch.plug_158d0001dad4ed
map:
# Track the sun
sun:
# Weather prediction
  - platform: yr
# Text to speech
#tts:
  #- platform: google
#logger
logger:
  default: error
# Cloud
#cloud:
#Alarme
alarm_control_panel: !include alarm.yaml
panel_custom: !include panel_custom.yaml
device_tracker: !include device_tracker.yaml
group: !include_dir_merge_named groups
cover: !include cover.yaml
script: !include script.yaml
# Xiaomi You can leave MAC empty if you only have one gateway.
xiaomi_aqara:
   discovery_retry: 5
   gateways:
       - mac: !secret xiaomi_mac
         key: !secret xiaomi_key
         host: !secret xiaomi_ip
#Configurar CAM 1080P
# ffmpeg: ffmpeg_bin: /usr/bin/ffmpeg
# camera:
# - platform: yi
# name: Corredor Cam
# host: '192.168.0.51'
# user: root
# password: ***
# path: /tmp/sd/record
# - platform: local_file
# file_path: /home/pi/screenshot.png
#Example configuration.yaml entry
light:
  - platform: yeelight
    devices:
      192.168.0.56:
      192.168.0.151:
  - platform: xiaomi_miio
    host: 192.168.0.55
    token: f3f7be7ddb8795e3849f461bd9d51c39
    #token: 8021de8fe7c2366a6b1fb2f91e2a81f3
    model: philips.light.bulb
    host: 192.168.0.54
    token: d1d260326e671529bc43a3bcf889a778
    host: 192.168.0.52
    token: 292394575f06276c6ad5270eea2072d5
# Consumos Diarios
history_graph:
    graph_daily_consumption:
       # - sensor.plug_power_consumed_kwh
        - sensor.consumption_daily_total_kwh
      hours_to_show: 24
      refresh: 30
     ## Temperaturas Interiores
    graph_interior_temperature:
      name: Temperaturas Interiores
         - sensor.temperature_158d0001ab26e2
         - sensor.temperature_158d0001585314
      hours_to_show: 24
      refresh: 30
    graph_interior_humidade:
      name: Humidade Interiores
         - sensor.humidity_158d0001ab26e2
         - sensor.humidity_158d0001585314
      hours_to_show: 24
      refresh: 30
O erro que dá é relativo a linha 101, e na linha 101 encontras isso:
Está certo?
Já descobri o problema.
Não tinha nada a ver com o file configuration.yaml mas sim com outro ficheiro. Tinha um erro numa automação.
o problema está num dos ficheiros dentro do automations.yaml e nesse mexes-te de certeza!
