Erro ao atualizar zigbee2mqtt
Tenho Hassio v.0.104.3 a correr num RPi3, com add-on zigbee2mqtt. Para a rede zigbee estou a usar uma pen usb CC2531.
Até à versão 1.5.1 do zigbee2mqtt tudo funcionou bem. Sempre que tento atualizar para uma versão mais recente dá-me erros no log e nenhum dispositivo zigbee funciona. Tenho que repor a versão 1.5.1 para funcionar.
Vou deixar aqui alguma informação para ver se me podem ajudar:
Log do zigbee2mqtt depois de atualizar para a versão 1.9.0:
./run.sh: line 17: [Info] Configuration backup found in /share/zigbee2mqtt/.configuration.yaml.bk. Skipping config backup.: No such file or directory
[Info] Socat is DISABLED and not started
2020-02-03T23:00:54: PM2 log: Launching in no daemon mode
2020-02-03T23:00:54: PM2 log: App [npm:0] starting in -fork mode-
2020-02-03T23:00:55: PM2 log: App [npm:0] online
> zigbee2mqtt@1.9.0 start /zigbee2mqtt-1.9.0
> node index.js
zigbee2mqtt:info  2020-02-03 23:00:59: Logging to console and directory: '/share/zigbee2mqtt/log/2020-02-03.23-00-59'
zigbee2mqtt:info  2020-02-03 23:00:59: Starting zigbee2mqtt version 1.9.0 (commit #unknown)
zigbee2mqtt:info  2020-02-03 23:00:59: Starting zigbee-herdsman...
zigbee2mqtt:error 2020-02-03 23:01:07: Error while starting zigbee-herdsman
zigbee2mqtt:error 2020-02-03 23:01:07: Failed to start zigbee
zigbee2mqtt:error 2020-02-03 23:01:07: Exiting...
zigbee2mqtt:error 2020-02-03 23:01:07: Error: SRSP - SYS - version after 6000ms
    at Timeout._onTimeout (/zigbee2mqtt-1.9.0/node_modules/zigbee-herdsman/dist/utils/waitress.js:44:24)
    at listOnTimeout (internal/timers.js:531:17)
    at processTimers (internal/timers.js:475:7)
npm
 ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! zigbee2mqtt@1.9.0 start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.9.0 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2020-02-03T23_01_07_448Z-debug.log
2020-02-03T23:01:07: PM2 log: App [npm:0] exited with code [1] via signal [SIGINT]
2020-02-03T23:01:07: PM2 log: App [npm:0] starting in -fork mode-
2020-02-03T23:01:07: PM2 log: App [npm:0] online
Hardware (pen usb):
* serial:
  * /dev/ttyAMA0
  * /dev/ttyACM0
  * /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001938AB49-if00
* input:
* disk:
  * /dev/mmcblk0p4
  * /dev/mmcblk0p6
  * /dev/mmcblk0p1
  * /dev/mmcblk0p2
  * /dev/mmcblk0p7
  * /dev/mmcblk0
  * /dev/mmcblk0p5
  * /dev/mmcblk0p3
  * /dev/mmcblk0p8
* gpio:
  * gpiochip0
  * gpiochip128
* audio:
  * 0:
    * name: bcm2835_alsa - bcm2835 ALSA
    * type: ALSA
    * devices:
      * [object Object]
      * [object Object]
Configuração do zigbee2mqtt:
  "data_path": "/share/zigbee2mqtt",
  "devices": "devices.yaml",
  "groups": "groups.yaml",
  "homeassistant": true,
  "permit_join": false,
  "mqtt": {
    "base_topic": "zigbee2mqtt",
    "server": "mqtt://192.168.1.XXX:1883",
    "user": "XXXXXXXX",
    "password": "XXXXXXX"
  "serial": {
    "port": "/dev/ttyACM0"
  "advanced": {
    "pan_id": 6754,
    "channel": 11,
    "network_key": [
      1,
      3,
      5,
      7,
      9,
      11,
      13,
      15,
      0,
      2,
      4,
      6,
      8,
      10,
      12,
      13
    "availability_blacklist": []
  "ban": [],
  "whitelist": [],
  "queue": {}
Log do sistema:
20-02-03 22:40:52 INFO (SyncWorker_14) [hassio.docker.interface] Stop addon_7ad98f9c_zigbee2mqtt application
20-02-03 22:40:53 INFO (SyncWorker_14) [hassio.docker.interface] Clean addon_7ad98f9c_zigbee2mqtt application
20-02-03 22:41:04 INFO (SyncWorker_7) [hassio.docker.addon] Start Docker add-on dwelch2101/zigbee2mqtt-armhf with version 1.9.0
20-02-03 22:43:32 INFO (SyncWorker_13) [hassio.docker.interface] Stop addon_7ad98f9c_zigbee2mqtt application
20-02-03 22:43:33 INFO (SyncWorker_13) [hassio.docker.interface] Clean addon_7ad98f9c_zigbee2mqtt application
20-02-03 22:43:36 INFO (SyncWorker_6) [hassio.docker.addon] Start Docker add-on dwelch2101/zigbee2mqtt-armhf with version 1.9.0
20-02-03 22:45:35 INFO (SyncWorker_10) [hassio.docker.interface] Stop addon_7ad98f9c_zigbee2mqtt application
20-02-03 22:45:36 INFO (SyncWorker_10) [hassio.docker.interface] Clean addon_7ad98f9c_zigbee2mqtt application
20-02-03 22:45:39 INFO (SyncWorker_5) [hassio.docker.addon] Start Docker add-on dwelch2101/zigbee2mqtt-armhf with version 1.9.0
20-02-03 22:47:19 INFO (SyncWorker_6) [hassio.docker.interface] Stop addon_7ad98f9c_zigbee2mqtt application
20-02-03 22:47:20 INFO (SyncWorker_6) [hassio.docker.interface] Clean addon_7ad98f9c_zigbee2mqtt application
20-02-03 22:47:23 INFO (SyncWorker_12) [hassio.docker.addon] Start Docker add-on dwelch2101/zigbee2mqtt-armhf with version 1.9.0
20-02-03 23:00:42 INFO (SyncWorker_2) [hassio.docker.interface] Stop addon_7ad98f9c_zigbee2mqtt application
20-02-03 23:00:43 INFO (SyncWorker_2) [hassio.docker.interface] Clean addon_7ad98f9c_zigbee2mqtt application
20-02-03 23:00:49 INFO (SyncWorker_16) [hassio.docker.addon] Start Docker add-on dwelch2101/zigbee2mqtt-armhf with version 1.9.0
Possivelmente terás que actualizar o firmware.
Alguém me sabe dizer qual é a diferença entre o add-on zigbee2mqtt e o zigbee2mqtt-edge?
Acabei de instalar o zigbee2mqtt-edge e funciona tudo.
Log
  "mqtt": {
    "user": "XXXXXX",
    "password": "XXXXXX"
  "serial": {
  "advanced": {
    "pan_id": 6754,
    "channel": 11,
    "network_key": [
      1,
      3,
      5,
      7,
      9,
      11,
      13,
      15,
      0,
      2,
      4,
      6,
      8,
      10,
./run.sh: line 24: [Info] Configuration backup found in /share/zigbee2mqtt/.configuration.yaml.bk. Skipping config backup.: No such file or directory
      12,
      13
  "ban": [],
  "whitelist": [],
  "queue": {},
  "socat": {
    "enabled": false,
    "master": "pty,raw,echo=0,link=/dev/ttyZ2M,mode=777",
    "slave": "tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5",
    "restartdelay": 1.0,
    "initialdelay": 1.0,
    "options": "-d -d",
    "log": false
}Debug information end
2020-02-04T00:02:19: PM2 log: Launching in no daemon mode
2020-02-04T00:02:19: PM2 log: App [npm:0] starting in -fork mode-
2020-02-04T00:02:19: PM2 log: App [npm:0] online
> zigbee2mqtt@1.9.0-dev start /app
> node index.js
zigbee2mqtt:info  2020-02-04 00:02:24: Logging to console and directory: '/share/zigbee2mqtt/log/2020-02-04.00-02-24'
zigbee2mqtt:info  2020-02-04 00:02:24: Starting zigbee2mqtt version 1.9.0-dev (commit #cf1bb386ead98a78b6b3bfed01e8d151cc7e9c6c)
zigbee2mqtt:info  2020-02-04 00:02:24: Starting zigbee-herdsman...
zigbee2mqtt:info  2020-02-04 00:02:32: zigbee-herdsman started
zigbee2mqtt:info  2020-02-04 00:02:32: Coordinator firmware version: '{"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":0,"maintrel":0,"revision":""}}'
zigbee2mqtt:info  2020-02-04 00:02:32: Currently 5 devices are joined:
zigbee2mqtt:info  2020-02-04 00:02:32: XiaomiTH Sala (0x00158d000346b928): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
zigbee2mqtt:info  2020-02-04 00:02:32: Sensor Porta Entrada (0x00158d00039733fa): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
zigbee2mqtt:info  2020-02-04 00:02:32: Interruptor Ikea 1 (0x000d6ffffea45d8b): E1743 - IKEA TRADFRI ON/OFF switch (EndDevice)
zigbee2mqtt:info  2020-02-04 00:02:32: Sensor Porta Sótão (0x00158d0003ef3239): MCCGQ11LM - Xiaomi Aqara door & window contact sensor (EndDevice)
zigbee2mqtt:info  2020-02-04 00:02:32: Sensor Cozinha (0x00158d00034d0bfc): RTCGQ11LM - Xiaomi Aqara human body movement and illuminance sensor (EndDevice)
zigbee2mqtt:info  2020-02-04 00:02:32: Zigbee: disabling joining new devices.
zigbee2mqtt:info  2020-02-04 00:02:32: Connecting to MQTT server at mqtt://192.168.1.119:1883
zigbee2mqtt:info  2020-02-04 00:02:33: Connected to MQTT server
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'zigbee2mqtt/XiaomiTH Sala', payload '{"battery":91,"voltage":2985,"temperature":19.72,"humidity":68.89,"pressure":1010,"linkquality":89}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'zigbee2mqtt/Sensor Porta Entrada', payload '{"battery":91,"voltage":2985,"contact":true,"linkquality":81}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'zigbee2mqtt/Sensor Porta Sótão', payload '{"battery":86,"voltage":2975,"contact":true,"linkquality":7}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'zigbee2mqtt/Sensor Cozinha', payload '{"battery":97,"voltage":2995,"illuminance":0,"illuminance_lux":0,"linkquality":57,"occupancy":true}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"version":"1.9.0-dev","commit":"cf1bb386ead98a78b6b3bfed01e8d151cc7e9c6c","coordinator":{"type":"zStack12","meta":{"transportrev":2,"product":0,"majorrel":2,"minorrel":0,"maintrel":0,"revision":""}},"log_level":"info","permit_join":false}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x00158d000346b928/temperature/config', payload '{"unit_of_measurement":"°C","device_class":"temperature","value_template":"{{ value_json.temperature }}","state_topic":"zigbee2mqtt/XiaomiTH Sala","json_attributes_topic":"zigbee2mqtt/XiaomiTH Sala","name":"XiaomiTH Sala_temperature","unique_id":"0x00158d000346b928_temperature_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d000346b928"],"name":"XiaomiTH Sala","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x00158d000346b928/humidity/config', payload '{"unit_of_measurement":"%","device_class":"humidity","value_template":"{{ value_json.humidity }}","state_topic":"zigbee2mqtt/XiaomiTH Sala","json_attributes_topic":"zigbee2mqtt/XiaomiTH Sala","name":"XiaomiTH Sala_humidity","unique_id":"0x00158d000346b928_humidity_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d000346b928"],"name":"XiaomiTH Sala","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x00158d000346b928/pressure/config', payload '{"unit_of_measurement":"hPa","device_class":"pressure","value_template":"{{ value_json.pressure }}","state_topic":"zigbee2mqtt/XiaomiTH Sala","json_attributes_topic":"zigbee2mqtt/XiaomiTH Sala","name":"XiaomiTH Sala_pressure","unique_id":"0x00158d000346b928_pressure_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d000346b928"],"name":"XiaomiTH Sala","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x00158d000346b928/battery/config', payload '{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/XiaomiTH Sala","json_attributes_topic":"zigbee2mqtt/XiaomiTH Sala","name":"XiaomiTH Sala_battery","unique_id":"0x00158d000346b928_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d000346b928"],"name":"XiaomiTH Sala","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x00158d000346b928/linkquality/config', payload '{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/XiaomiTH Sala","json_attributes_topic":"zigbee2mqtt/XiaomiTH Sala","name":"XiaomiTH Sala_linkquality","unique_id":"0x00158d000346b928_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d000346b928"],"name":"XiaomiTH Sala","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/binary_sensor/0x00158d00039733fa/contact/config', payload '{"payload_on":false,"payload_off":true,"value_template":"{{ value_json.contact }}","device_class":"door","state_topic":"zigbee2mqtt/Sensor Porta Entrada","json_attributes_topic":"zigbee2mqtt/Sensor Porta Entrada","name":"Sensor Porta Entrada_contact","unique_id":"0x00158d00039733fa_contact_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00039733fa"],"name":"Sensor Porta Entrada","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara door & window contact sensor (MCCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x00158d00039733fa/battery/config', payload '{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/Sensor Porta Entrada","json_attributes_topic":"zigbee2mqtt/Sensor Porta Entrada","name":"Sensor Porta Entrada_battery","unique_id":"0x00158d00039733fa_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00039733fa"],"name":"Sensor Porta Entrada","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara door & window contact sensor (MCCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x00158d00039733fa/linkquality/config', payload '{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/Sensor Porta Entrada","json_attributes_topic":"zigbee2mqtt/Sensor Porta Entrada","name":"Sensor Porta Entrada_linkquality","unique_id":"0x00158d00039733fa_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00039733fa"],"name":"Sensor Porta Entrada","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara door & window contact sensor (MCCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x000d6ffffea45d8b/click/config', payload '{"icon":"mdi:toggle-switch","value_template":"{{ value_json.click }}","state_topic":"zigbee2mqtt/Interruptor Ikea 1","json_attributes_topic":"zigbee2mqtt/Interruptor Ikea 1","name":"Interruptor Ikea 1_click","unique_id":"0x000d6ffffea45d8b_click_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffea45d8b"],"name":"Interruptor Ikea 1","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"TRADFRI ON/OFF switch (E1743)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x000d6ffffea45d8b/battery/config', payload '{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/Interruptor Ikea 1","json_attributes_topic":"zigbee2mqtt/Interruptor Ikea 1","name":"Interruptor Ikea 1_battery","unique_id":"0x000d6ffffea45d8b_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffea45d8b"],"name":"Interruptor Ikea 1","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"TRADFRI ON/OFF switch (E1743)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x000d6ffffea45d8b/linkquality/config', payload '{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/Interruptor Ikea 1","json_attributes_topic":"zigbee2mqtt/Interruptor Ikea 1","name":"Interruptor Ikea 1_linkquality","unique_id":"0x000d6ffffea45d8b_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x000d6ffffea45d8b"],"name":"Interruptor Ikea 1","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"TRADFRI ON/OFF switch (E1743)","manufacturer":"IKEA"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/binary_sensor/0x00158d0003ef3239/contact/config', payload '{"payload_on":false,"payload_off":true,"value_template":"{{ value_json.contact }}","device_class":"door","state_topic":"zigbee2mqtt/Sensor Porta Sótão","json_attributes_topic":"zigbee2mqtt/Sensor Porta Sótão","name":"Sensor Porta Sótão_contact","unique_id":"0x00158d0003ef3239_contact_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d0003ef3239"],"name":"Sensor Porta Sótão","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara door & window contact sensor (MCCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x00158d0003ef3239/battery/config', payload '{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/Sensor Porta Sótão","json_attributes_topic":"zigbee2mqtt/Sensor Porta Sótão","name":"Sensor Porta Sótão_battery","unique_id":"0x00158d0003ef3239_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d0003ef3239"],"name":"Sensor Porta Sótão","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara door & window contact sensor (MCCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x00158d0003ef3239/linkquality/config', payload '{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/Sensor Porta Sótão","json_attributes_topic":"zigbee2mqtt/Sensor Porta Sótão","name":"Sensor Porta Sótão_linkquality","unique_id":"0x00158d0003ef3239_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d0003ef3239"],"name":"Sensor Porta Sótão","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara door & window contact sensor (MCCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/binary_sensor/0x00158d00034d0bfc/occupancy/config', payload '{"payload_on":true,"payload_off":false,"value_template":"{{ value_json.occupancy }}","device_class":"motion","state_topic":"zigbee2mqtt/Sensor Cozinha","json_attributes_topic":"zigbee2mqtt/Sensor Cozinha","name":"Sensor Cozinha_occupancy","unique_id":"0x00158d00034d0bfc_occupancy_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00034d0bfc"],"name":"Sensor Cozinha","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara human body movement and illuminance sensor (RTCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x00158d00034d0bfc/illuminance/config', payload '{"unit_of_measurement":"lx","device_class":"illuminance","value_template":"{{ value_json.illuminance }}","state_topic":"zigbee2mqtt/Sensor Cozinha","json_attributes_topic":"zigbee2mqtt/Sensor Cozinha","name":"Sensor Cozinha_illuminance","unique_id":"0x00158d00034d0bfc_illuminance_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00034d0bfc"],"name":"Sensor Cozinha","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara human body movement and illuminance sensor (RTCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x00158d00034d0bfc/battery/config', payload '{"unit_of_measurement":"%","device_class":"battery","value_template":"{{ value_json.battery }}","state_topic":"zigbee2mqtt/Sensor Cozinha","json_attributes_topic":"zigbee2mqtt/Sensor Cozinha","name":"Sensor Cozinha_battery","unique_id":"0x00158d00034d0bfc_battery_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00034d0bfc"],"name":"Sensor Cozinha","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara human body movement and illuminance sensor (RTCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
zigbee2mqtt:info  2020-02-04 00:02:33: MQTT publish: topic 'homeassistant/sensor/0x00158d00034d0bfc/linkquality/config', payload '{"icon":"mdi:signal","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/Sensor Cozinha","json_attributes_topic":"zigbee2mqtt/Sensor Cozinha","name":"Sensor Cozinha_linkquality","unique_id":"0x00158d00034d0bfc_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00034d0bfc"],"name":"Sensor Cozinha","sw_version":"Zigbee2mqtt 1.9.0-dev","model":"Aqara human body movement and illuminance sensor (RTCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
Será que agora posso desinstalar o add-on do zigbee2mqtt normal? Ou tem que ficar os dois?
Isto está escrito dentro do próprio HA…
“Development build”. É tipo uma versão beta?!
Mas devo manter os dois add-on’s ou elimino o zigbee2mqtt?
Sim, é tipo uma versão beta e só podes manter um addon do Z2M.
Obrigado @j_assuncao.
Já desinstalei o add-on zigbee2mqtt (normal) e vou manter o zigbee2mqtt-edge porque funciona perfeitamente.
Portanto @RodolfoVieira ainda bem que não foi preciso atualizar o firmware da pen usb.
A actualização do firmware da pen será inevitável a curto/médio prazo. Mais vale fazer já do que fazer um update ao addon e ficares sem conseguir utilizar a rede Zigbee até fazeres o update ao firmware…
Ok. Só estava a evitar isso porque tenho que pedir a terceiros.
Vou ter que “chatear” o meu amigo @sslopes.
Tenho a certeza que o @sslopes não se importa em fazer esse favor, mas se precisares de alguém daí da zona também se arranja.
@nmota Quando quiseres. Ainda ontem flashei uma para mim (CC2531 com antena)
Obrigado @sslopes. Um dia destes ligo-te para isso e para trocarmos algumas ideias.
