Pessoal, estou o seguinte problemas em quase todos addons, exemplo NODE-RED.
Alguém sabe como resolver ?
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[19:09:09] FATAL:
[19:09:09] FATAL: SSL has been enabled using the 'ssl' option,
[19:09:09] FATAL: this requires a SSL certificate file which is
[19:09:09] FATAL: configured using the 'certfile' option in the
[19:09:09] FATAL: add-on configuration.
[19:09:09] FATAL:
[19:09:09] FATAL: Unfortunately, the file specified in the
[19:09:09] FATAL: 'certfile' option does not exists.
[19:09:09] FATAL:
[19:09:09] FATAL: Please ensure the certificate file exists and
[19:09:09] FATAL: is placed in the Hass.io '/ssl/' directory.
[19:09:09] FATAL:
[19:09:09] FATAL: In case you don't have SSL yet, consider getting
[19:09:09] FATAL: a SSL certificate or setting the 'ssl' option
[19:09:09] FATAL: to 'false' in case you are not planning on using
[19:09:09] FATAL: SSL with this add-on.
[19:09:09] FATAL:
[19:09:09] FATAL: Check the add-on manual for more information.
[19:09:09] FATAL:
[cont-init.d] nginx.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
