Entidades SONOFF no status restore
Sou novato nestas andanças e tenho tentado entrar no mundo do home assistant.
Consegui adicionar dispositivos sonoff sem flashar atraves do HACS e estava tudo a funcionar bem até à 1 dia atras, quando alguns dos dispositivos ficaram offline.
Se for às entidades verifico este icon que não faço ideia o que indica
tenho outros dispositivos sonoff e estes estao a funicionar.
Os dispositivos que estão offline no HA consigo aceder atraves da app da ewelink.
Alguem consegue ajudar?
Já verificaste os logs?
Que erros tens?
Desculpa a demora Rodolfo, entretanto fiz restore a tudo e esteve estavel durante 2 dias.
O log é este:
2021-04-09 22:56:51 WARNING (MainThread) [homeassistant.loader] You are using a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-04-09 22:56:51 WARNING (MainThread) [homeassistant.loader] You are using a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-04-09 22:57:00 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 899dfe6e9fd50037927902461b940f52a90778bed45765255d3423faf290ac50 from 144.64.6.240
2021-04-09 22:57:01 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 899dfe6e9fd50037927902461b940f52a90778bed45765255d3423faf290ac50 from 144.64.6.240
2021-04-09 22:57:52 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 899dfe6e9fd50037927902461b940f52a90778bed45765255d3423faf290ac50 from 144.64.6.240
2021-04-09 22:59:32 ERROR (MainThread) [custom_components.sonoff.sonoff_cloud] Coolkit API error: Cannot connect to host eu-api.coolkit.cc:8080 ssl:default [Name does not resolve]
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 999, in _create_direct_connection
hosts = await asyncio.shield(host_resolved)
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 865, in _resolve_host
addrs = await self._resolver.resolve(host, port, family=self._family)
File “/usr/local/lib/python3.8/site-packages/aiohttp/resolver.py”, line 31, in resolve
infos = await self._loop.getaddrinfo(
File “/usr/local/lib/python3.8/asyncio/base_events.py”, line 825, in getaddrinfo
return await self.run_in_executor(
File “/usr/local/lib/python3.8/concurrent/futures/thread.py”, line 57, in run
result = self.fn(*self.args, **self.kwargs)
File “/usr/local/lib/python3.8/socket.py”, line 918, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -2] Name does not resolve
The above exception was the direct cause of the following exception:
File “/config/custom_components/sonoff/sonoff_cloud.py”, line 148, in _api
r = await coro
File “/usr/local/lib/python3.8/site-packages/aiohttp/client.py”, line 520, in _request
conn = await self._connector.connect(
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 535, in connect
proto = await self._create_connection(req, traces, timeout)
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 892, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File “/usr/local/lib/python3.8/site-packages/aiohttp/connector.py”, line 1011, in _create_direct_connection
raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host eu-api.coolkit.cc:8080 ssl:default [Name does not resolve]
2021-04-09 22:59:32 ERROR (MainThread) [custom_components.sonoff.sonoff_cloud] Login error: None
2021-04-09 22:59:32 WARNING (MainThread) [custom_components.sonoff] Can’t connect to eWeLink Cloud
Pelo erro que aparece o equipamento onde tens o HA instalado não se está a conseguir ligar a net por algum motivo.
Fiz reboot a Há e já estão a funcionar novamente
2025
