Dificuldade com minha primeira automação com sonoff mofificado
Ola a todos.
Estou começando agora o meu estudo sobre HA.
Com a ajuda que já recebi aqui no fórum, consegui editar os arquivos .yaml.
No entanto ainda preciso de ajuda para que o HA reconheça meus devices.
Tenho um sonoff que modifiquei o firmware dela com o seguinte código:
MQTT Light for Home-Assistant - NodeMCU (ESP8266)
https://home-assistant.io/components/light.mqtt/
Libraries :
- ESP8266 core for Arduino : https://github.com/esp8266/Arduino
- PubSubClient : https://github.com/knolleary/pubsubclient
Sources :
- File > Examples > ES8266WiFi > WiFiClient
- File > Examples > PubSubClient > mqtt_auth
- File > Examples > PubSubClient > mqtt_esp8266
Schematic :
- https://github.com/mertenats/open-home-automation/blob/master/ha_mqtt_light/Schematic.png
- GND - LED - Resistor 220 Ohms - D1/GPIO5
Configuration (HA) :
light:
platform: mqtt
state_topic: 'iead/light1/status'
command_topic: 'iead/light1/switch'
optimistic: false
Wilson S.N. - v1.1 - 11.2018
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#define MQTT_VERSION MQTT_VERSION_3_1_1
// Wifi: SSID and password
const char* WIFI_SSID = "wifi";
const char* WIFI_PASSWORD = "minhasenha";
// MQTT: ID, server IP, port, username and password
const PROGMEM char* MQTT_CLIENT_ID = "gate_light";
const PROGMEM char* MQTT_SERVER_IP = "192.168.15.9";
const PROGMEM uint16_t MQTT_SERVER_PORT = 1883;
const PROGMEM char* MQTT_USER = "MQTT_wilson";
const PROGMEM char* MQTT_PASSWORD = "sennha_do_wilson";
// MQTT: topics
const char* MQTT_LIGHT_STATE_TOPIC = "iead/light1/status";
const char* MQTT_LIGHT_COMMAND_TOPIC = "iead/light1/switch";
// payloads by default (on/off)
const char* LIGHT_ON = "ON";
const char* LIGHT_OFF = "OFF";
const PROGMEM uint8_t LED_PIN = 12;
boolean m_light_state = false; // light is turned off by default
WiFiClient wifiClient;
PubSubClient client(wifiClient);
// function called to publish the state of the light (on/off)
void publishLightState() {
if (m_light_state) {
client.publish(MQTT_LIGHT_STATE_TOPIC, LIGHT_ON, true);
} else {
client.publish(MQTT_LIGHT_STATE_TOPIC, LIGHT_OFF, true);
// function called to turn on/off the light
void setLightState() {
digitalWrite(LED_PIN, HIGH);
Serial.println("INFO: Turn light on...");
} else {
digitalWrite(LED_PIN, LOW);
Serial.println("INFO: Turn light off...");
// function called when a MQTT message arrived
void callback(char* p_topic, byte* p_payload, unsigned int p_length) {
// concat the payload into a string
String payload;
for (uint8_t i = 0; i < p_length; i++) {
payload.concat((char)p_payload[i]);
// handle message topic
if (String(MQTT_LIGHT_COMMAND_TOPIC).equals(p_topic)) {
// test if the payload is equal to "ON" or "OFF"
if (payload.equals(String(LIGHT_ON))) {
if (m_light_state != true) {
m_light_state = true;
setLightState();
publishLightState();
} else if (payload.equals(String(LIGHT_OFF))) {
if (m_light_state != false) {
setLightState();
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.println("INFO: Attempting MQTT connection...");
// Attempt to connect
if (client.connect(MQTT_CLIENT_ID, MQTT_USER, MQTT_PASSWORD)) {
Serial.println("INFO: connected");
// Once connected, publish an announcement...
// ... and resubscribe
client.subscribe(MQTT_LIGHT_COMMAND_TOPIC);
} else {
Serial.print("ERROR: failed, rc=");
Serial.print(client.state());
Serial.println("DEBUG: try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void setup() {
// init the serial
Serial.begin(115200);
// init the led
pinMode(LED_PIN, OUTPUT);
analogWriteRange(255);
setLightState();
// init the WiFi connection
Serial.println();
Serial.println();
Serial.print("INFO: Connecting to ");
WiFi.mode(WIFI_STA);
Serial.println(WIFI_SSID);
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("INFO: WiFi connected");
Serial.print("INFO: IP address: ");
Serial.println(WiFi.localIP());
// init the MQTT connection
client.setServer(MQTT_SERVER_IP, MQTT_SERVER_PORT);
client.setCallback(callback);
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
Consigo compilar e gravar no módulo sonoff, utilizei também as configurações para o HA conforme sugerido no próprio código fonte acima. Minha configuração de configuration.yaml. Ficou assim:
 homeassistant:
  latitude: 0
  longitude: 0
  elevation: 0
  unit_system: metric
  time_zone: UTC
  # Customization file
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
# http:
#   base_url: example.duckdns.org:8123
# the developers to assist with development of Home Assistant.
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
discovery:
conversation:
# Enables support for tracking state changes over time
history:
logbook:
map:
# Track the sun
sun:
# Sensors
  # Weather prediction
  - platform: yr
  - platform: random
# Text to speech
tts:
  - platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
automation:
  - alias: Check sensor value and show notification
      platform: numeric_state
      entity_id: sensor.random_sensor
      above: 10
      service: persistent_notification.create
        message: "Sensor value greater than 10"
light:
      platform: mqtt
      optimistic: false
mqtt:
    broker: localhost
    port: 1883
    client_id: gate_light
    keepalive: 60
    username: !secret username_mqtt
    password: !secret password_mqtt
    protocol: 3.1.1
    discovery: true
panel_iframe:
  configurator:
    title: Configurator
    icon: mdi:wrench
    url: http://hassio.local:3218
O HA não acusa erro, mas o sonoff não aparece, e portanto não pode ser acessado. Como posso resolver isto? Será que não configurei corretamente o mqtt?
E sim estou lendo a documentação do HA, mas como estou no início, estou tendo dificuldades.
Obrigado pela paciência de todos.
Tens vários exemplos no fórum de como configurar o ficheiro configuration.yaml
@wilson quando publicares código deves sublinhar o texto que queres transformar em código e clicar no ícone </>. Deverá existir um espaço antes e outro depois do bloco de código para que funcione correctamente.
Quando publicares código muito longo, como por exemplo deves utilizar um serviço externo como o Hastebin ou o Pastebin e depois colocar aqui o link.
Peço-te que alteres por favor a tua publicação inicial pois está demasiado confusa. Assim como está será difícil alguém te poder ajudar.
ok. editei o que escrevi. acho que ficou mais fácil agora.
É estranho o HA não dar nenhum erro pois a primeira coisa que salta à vista no configuration.yaml é que a formatação nas entradas light: e mqtt: está errada.
Os ficheiros YAML são muito sensíveis ao espaçamento, devendo sempre ser utilizados em múltiplos de 2.
Podes ler um pouco mais sobre o YAML aqui:
http://yaml.org/spec/1.2/spec.html
Na verdade os espaços estão com multiplos de 2.
Para verificar, fiz teste diminuindo e aumentando os espaços. realmente a verificação de configurações acusa erro quando mudo. Mas quando deixo tudo certo, nenhum erro é acusado.
Realmente ainda não consegui fazer o sonoff funcionar.
Será que o defeito não esta nas configurações do mqtt e das configurações do device?
oOs códigos em destaque estão aqui:
light:
      platform: mqtt
      state_topic: "iead/light1/status"
      command_topic: "iead/light1/switch"
      optimistic: false
mqtt:
    broker: localhost
    port: 1883
    keepalive: 60
    protocol: 3.1.1
    discovery: true
consegui colocar um ip fixo na hasp pi.
192.168.15.9
no sonoff utilizei os mesmos endereços. será que existe algum conflito ai?
const char* WIFI_SSID = "wifi-iead";
const char* WIFI_PASSWORD = "xxxxxxxxxxxxxxx";
// MQTT: topics
Comigo as coisas sempre são mais difíceis. Espero que consiga resolver este problema.
Experimenta trocar broker: localhost por broker: 192.168.15.9 e retira o optimistic da entrada light:
Bem, as coisas são difíceis porque estas a seguir o caminho mais difícil! Porque não flashar o sonoff com tasmota?! Muito mais simples…
Claro que usar código personalizado é mais desafiante, mas se estás a ter dificuldades se calhar o ideal era mudares a abordagem…
Verdade, vou tentar usar o tasmota ainda hoje.
Mas olhem o que descobri:
O sonoff se conecta a minha rede wifi, ele não consegue é se conectar com o broker. estou vendo isto pela inteface do arduino.
No log do HA vejo que ocerre algum erro com o mqtt também. Acredito que o defeito esteja nas configurações do broker mosquito. Vou pesquisar por aqui, mas se alguém souber de alguma coisa eu agradeço.
olhem a resposta do módulo sonoff
INFO: Connecting to wifi-iead
INFO: IP address: 192.168.15.12
ERROR: failed, rc=-2DEBUG: try again in 5 seconds
agora o log do HA
INFO:2018-11-12 19:01:14,486:__main__:Starting server
INFO:2018-11-12 19:01:14,487:__main__:Listening on: http://0.0.0.0:3218
A porta 3218 não pertence ao MQTT…
Pois é . Acredito que o defeito esteja nas configurações do mqtt.
alterei esta linha no programa do sonoff:
const PROGMEM char* MQTT_SERVER_IP = “192.168.1.16”;
e agora a resposta do módulo é esta:
a resposta do HA é
[INFO] Setup mosquitto configuration
[WARN] SSL not enabled - No valid certs found!
[INFO] No local user available
[INFO] Initialize Hass.io Add-on services
[INFO] Initialize Home Assistant discovery
[INFO] Start Mosquitto daemon
1542049222: mosquitto version 1.4.15 (build date 2018-03-04 15:35:59+0000) starting
1542049222: Config loaded from /etc/mosquitto.conf.
1542049222: *** auth-plug: startup
1542049222: ** Configured order: http
1542049222: Opening ipv4 listen socket on port 1883.
1542049222: Opening ipv6 listen socket on port 1883.
1542049222: Opening websockets listen socket on port 1884.
1542049222: Warning: Mosquitto should not be run as root/administrator.
1542049251: New connection from 172.30.32.1 on port 1883.
[ERROR] Auth error with MQTT_wilson
1542049251: Socket error on client <unknown>, disconnecting.
1542051022: Saving in-memory database to /data/mosquitto.db.
O HA esta acusando erro de autenticação do mqtt.
Vou verificar estas configurações, mas se alguém souber qual o erro, por favor me ajude.
O que descobri agora.
Log
[INFO] Found local users inside config
1542055801: mosquitto version 1.4.15 (build date 2018-03-04 15:35:59+0000) starting
1542055801: Config loaded from /etc/mosquitto.conf.
1542055801: *** auth-plug: startup
1542055801: ** Configured order: http
1542055801: Opening ipv4 listen socket on port 1883.
1542055801: Opening ipv6 listen socket on port 1883.
1542055801: Opening websockets listen socket on port 1884.
1542055801: Warning: Mosquitto should not be run as root/administrator.
1542055830: New connection from 172.30.32.1 on port 1883.
[INFO] found MQTT_wilson on local database
1542055830: New client connected from 172.30.32.1 as gate_light (c1, k60, u'MQTT_wilson')
O que seria esta conexão 172.30.32.1 ?
Respondendo a mim mesmo.
Mudei o nome da authenticação mqtt e o resultado agora é:
Log
1542057778: mosquitto version 1.4.15 (build date 2018-03-04 15:35:59+0000) starting
1542057778: Config loaded from /etc/mosquitto.conf.
1542057778: *** auth-plug: startup
1542057778: ** Configured order: http
1542057778: Opening ipv4 listen socket on port 1883.
1542057778: Opening ipv6 listen socket on port 1883.
1542057778: Opening websockets listen socket on port 1884.
1542057778: Warning: Mosquitto should not be run as root/administrator.
1542057807: New connection from 172.30.32.1 on port 1883.
[INFO] found MQTT_big_iead_wilson on local database
1542057807: New client connected from 172.30.32.1 as gate_light (c1, k60, u'MQTT_big_iead_wilson').
o sonoff esta tentando se conectar com o ha, mais ainda assim esta faltando algo.
INFO: IP address: 192.168.15.5
a chave virtual de ligar e desligar o sonoff já aparece na tela principal do HA.
estamos caminhando.
uma ajudinha seria muito bom.
Olhem só. descobri que o endereço do mqtt deve ser o mesmo atribuido ao HA ou haspberry pi.
coloquei o mesmo endereço e o sonoff se conectou.
INFO: connected
o log do mosquito
Log
1542062678: mosquitto version 1.4.15 (build date 2018-03-04 15:35:59+0000) starting
1542062678: Config loaded from /etc/mosquitto.conf.
1542062678: *** auth-plug: startup
1542062678: ** Configured order: http
1542062678: Opening ipv4 listen socket on port 1883.
1542062678: Opening ipv6 listen socket on port 1883.
1542062678: Opening websockets listen socket on port 1884.
1542062678: Warning: Mosquitto should not be run as root/administrator.
1542062716: New connection from 192.168.15.5 on port 1883.
1542062716: New client connected from 192.168.15.5 as gate_light (c1, k15, u'MQTT_big_iead_wilson').
1542062828: Client gate_light has exceeded timeout, disconnecting.
1542062828: Socket error on client gate_light, disconnecting.
1542062835: New connection from 192.168.15.5 on port 1883.
1542062835: New client connected from 192.168.15.5 as gate_light (c1, k15, u'MQTT_big_iead_wilson').
1542064479: Saving in-memory database to /data/mosquitto.db.
1542064777: Client gate_light has exceeded timeout, disconnecting.
1542064777: Socket error on client gate_light, disconnecting.
1542064778: New connection from 192.168.15.5 on port 1883.
1542064778: New client connected from 192.168.15.5 as gate_light (c1, k15, u'MQTT_big_iead_wilson').
1542064800: Client gate_light has exceeded timeout, disconnecting.
1542064800: Socket error on client gate_light, disconnecting.
1542064800: New connection from 192.168.15.5 on port 1883.
1542064800: New client connected from 192.168.15.5 as gate_light (c1, k15, u'MQTT_big_iead_wilson').
Mas agora a chave virtual que deveria ativar e desativar o rele desapareceu do painel do HA. ???
O que eu estou fazendo de errado?
Quais as configurações do mqtt no tasmota?
Coloca o resultado do comando backlog status; status 1; status 2; status 5; status 6 na consola do tasmota
Ola amigo Nuno.
Não estou usando o tasmota ainda. estou usando um outro projeto chamado: OpenHome.
Peguei no github.
Mas também vou estudar tasmota, para me aperfeiçoar em HA.
Vou continuar aqui com a pesquisa do porque de não aparecer o comando na tela do HA.
Vamos em frente.
Socorro. Não sei como controlar este módulo pelo painel do HA. Alguém me ajude por favor.
