00:00:00 Project sonoff Sonoff Version 6.5.0(release-sonoff)-2_3_0
00:00:00 RUL: SWITCH2#BOOT=0 performs “publish2 cmnd/reedswitch/POWER2 OFF”
00:00:00 RSL: cmnd/reedswitch/POWER2 = OFF
00:00:00 WIF: Connecting to AP1 Wifi-lan1 in mode 11N as nodemcu2-3231…
00:00:03 WIF: Connected
00:00:03 HTP: Web server active on nodemcu2-3231 with IP address 192.168.1.70
23:40:27 MQT: Attempting connection…
23:40:29 MQT: Connected
23:40:29 MQT: tele/nodemcu2/LWT = Online (retained)
23:40:29 MQT: cmnd/nodemcu2/POWER =
23:40:29 MQT: stat/nodemcu2/RESULT = {“POWER5”:“OFF”}
23:40:29 MQT: stat/nodemcu2/POWER5 = OFF (retained)
23:40:29 MQT: tele/nodemcu2/INFO1 = {“Module”:“Generic”,“Version”:“6.5.0(release-sonoff)”,“FallbackTopic”:“cmnd/nodemcu2_fb/”,“GroupTopic”:“sonoffs”}
23:40:29 MQT: tele/nodemcu2/INFO2 = {“WebServerMode”:“Admin”,“Hostname”:“nodemcu2-3231”,“IPAddress”:“192.168.1.70”}
23:40:29 MQT: tele/nodemcu2/INFO3 = {“RestartReason”:“External System”}
23:40:29 MQT: stat/nodemcu2/RESULT = {“POWER1”:“OFF”}
23:40:29 MQT: stat/nodemcu2/POWER1 = OFF (retained)
23:40:29 MQT: stat/nodemcu2/RESULT = {“POWER2”:“OFF”}
23:40:29 MQT: stat/nodemcu2/POWER2 = OFF (retained)
23:40:29 MQT: stat/nodemcu2/RESULT = {“POWER3”:“OFF”}
23:40:29 MQT: stat/nodemcu2/POWER3 = OFF (retained)
23:40:29 MQT: stat/nodemcu2/RESULT = {“POWER4”:“OFF”}
23:40:29 MQT: stat/nodemcu2/POWER4 = OFF (retained)
23:40:30 MQT: stat/nodemcu2/RESULT = {“POWER3”:“OFF”}
23:40:30 MQT: stat/nodemcu2/POWER3 = OFF (retained)
23:40:30 MQT: stat/nodemcu2/RESULT = {“POWER4”:“OFF”}
23:40:30 MQT: stat/nodemcu2/POWER4 = OFF (retained)
23:40:37 MQT: tele/nodemcu2/STATE = {“Time”:“2019-04-06T23:40:37”,“Uptime”:“0T00:00:14”,“Vcc”:2.752,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:19,“POWER1”:“OFF”,“POWER2”:“OFF”,“POWER3”:“OFF”,“POWER4”:“OFF”,“POWER5”:“OFF”,“Wifi”:{“AP”:1,“SSId”:“Wifi-lan1”,“BSSId”:“C4:FF:1F:6A:E6:6C”,“Channel”:6,“RSSI”:78,“LinkCount”:1,“Downtime”:“0T00:00:03”}}
23:40:38 MQT: tele/nodemcu2/SENSOR = {“Time”:“2019-04-06T23:40:37”,“Switch2”:“OFF”}
Ok, já identifiquei o problema… Tenta assim…
rule1 on switch2#boot=1 do var1 ON endon on switch2#boot=0 do var1 OFF endon on Mqtt#Connected do backlog delay 10; publish2 cmnd/reedswitch/POWER2 %var1% endon
O problema era o Tasmota estar a enviar o estado antes de ter ligação ao MQTT.
Uma dúvida!
É possível ligar um interruptor fim de curso
em vez do reed switch
A idéa é verificar se uma caixa de correio é aberta.
Sim, podes ligar qualquer equipamento passivo que faça on/off.
Boa tarde pessoal, estou com um sonoff dual no portão da garagem. Ja consigo abrir e fechar o portão da garagem e o portão social, agora gostaria de acrescentar 2 sensores reed a esse mesmo sonoff dual, para verificar se os portões estão abertos ou fechados, procurei algo na internet mas so encontrei para sonoff basic, alguem poderia me explicar como eu poderia fazer a instalação desses 2 reeds??
