para os interessados, estive a “martelar” codigo para criar uma pagina de Web que permite ler, ajuda em perceber para quem tem problema de mqtt se o leitor esta a fazer leituras.
Obrigado ao Jorge Assunção que “roubei” parte do codigo dele para construir a página.
usem a versao do arduino ide que disponibilizei anteriormente que tem as librarias necessárias, e aparentemente estas librarias parecem estar a aguentar o leitor, o meu aguento 48H
#include <ESP8266WiFi.h>
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <ESP8266mDNS.h>
#include <PubSubClient.h>
#include <ArduinoOTA.h>
#include <SDM.h> //import SDM template library
//SDM<2400, 12, 13> sdm; //SDM120T baud, rx pin, tx pin
//SDM<4800, 12, 13> sdm; //SDM120C baud, rx pin, tx pin
//SDM<9600, 12, 13> sdm; //SDM630 baud, rx pin, tx pin
//or without parameters (default from SDM.h will be used):
ESP8266WebServer server(80);
const int led = 5;
SDM<2400, 12, 13, 4> sdm;
float m = 0;
char charBuf[50];
String s;
const char* ssid = "SSID"; // Wifi SSID
const char* password = "PASSWORD"; // Wifi password
const char* mqttClientName = "SDMWEB"; //will also be used hostname and OTA name
IPAddress ip(192,168,1,133); // IP address
IPAddress dns(192,168,1,254); // DNS server
IPAddress gateway(192,168,1,254); // Gateway
IPAddress subnet(255,255,255,0); // Subnet mask
const char* mqtt_server = "192.168.1.132";
#define mqtt_user "mqttuser"
#define mqtt_password "mqttpassword"
int MQTT_WILL_QOS = 1; // MQTT last will QoS (0,1 or 2)
int MQTT_WILL_RETAIN = 1; // MQTT last will retain (0 or 1)
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
//************* PROJECT AND VERSION **********************************************************************
const char* proj_ver = "Leitor MODBUS Eastron SDM230.v.0.1 (29/05/2018)"; // Project name and version
const char* todefine = ""; // Project name and version
char wattString[7]; // Variable -
char kwhString[7]; // Variable -
char powreading[7]; // Variable -
char amperreading[7]; // Variable -
double ampe; // Variable -
double poww; // Variable -
double kwhaccum; // Variable -
double voltage; // Variable -
double frequency; // Variable -
double pfactor; // Variable -
char kwhaccumString[7]; // Variable -
char voltagestring[7]; // Variable -
char frequencystring[7]; // Variable -
char pfactorstring[7]; // Variable -
float kwhReading; // Variable -
//************* CONFIG WEBSERVER ROOT PAGE ***************************************************************
String getPage(){ // Create webpage content
String page = "<!DOCTYPE html>";
page += "<html lang='en'>";
page += "<head>";
page += "<meta charset='utf-8'>";
page += "<meta http-equiv='X-UA-Compatible' content='IE=edge'>";
page += "<meta name='viewport' content='width=device-width, initial-scale=1'>";
page += "<meta http-equiv='refresh' content='15'/>";
page += "<link rel='shortcut icon' href='data:image/png;base64,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'>";
page += "<title>";
page += mqttClientName;
page += "</title>";
page += "<link rel='stylesheet' href='//maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap.min.css' integrity='sha384-BVYiiSIFeK1dGmJRAkycuHAHRg32OmUcww7on3RYdg4Va+PmSTsz/K68vbdEjh4u' crossorigin='anonymous'>";
page += "<link rel='stylesheet' href='//maxcdn.bootstrapcdn.com/bootstrap/3.3.7/css/bootstrap-theme.min.css' integrity='sha384-rHyoN1iRsVXV4nD0JutlnGaslCJuC7uwjduW9SVrLvRYooPp2bWYgmgJQIXwl/Sp' crossorigin='anonymous'>";
page += "<script src='//maxcdn.bootstrapcdn.com/bootstrap/3.3.7/js/bootstrap.min.js' integrity='sha384-Tc5IQib027qvyjSMfHjOMaLkfuWVxZxUPnCJA7l2mCWNIpG9mGCD8wGNIcPD7Txa' crossorigin='anonymous'></script>";
page += "<script src='https://ajax.googleapis.com/ajax/libs/jquery/3.2.0/jquery.min.js'></script>";
page += "</head>";
page += "<body>";
page += "<p></p>";
page += "<div class='container-fluid'>";
page += "<div class='row'>";
page += "<div class='col-md-12'>";
page += "<div class='jumbotron'>";
page += "<h2>";
page += proj_ver;
page += "</h2>";
page += "<p>This project uses a MQTT topic to store the accumulated kWh value, so that when there is a reboot, reset or power off the value won't be lost. <small><em style='color: #ababab;'>";
page += todefine;
page += "</em></small></p>";
page += "</div>";
page += "<div class='alert alert-dismissable alert-info'>";
page += "<button type='button' class='close' data-dismiss='alert' aria-hidden='true'>×</button>";
page += "<strong>Attention!</strong> This page auto-refreshes every 15 seconds.";
page += "</div>";
page += "</div>";
page += "</div>";
page += "<div class='col-md-4'>";
page += "<h3 class='text-primary'>Current Consumption</h3>";
page += "<p class='lead'>";
page += powreading;
page += " Wh</p>";
page += "</div>";
page += "<h3 class='text-primary'>Current Amperage</h3>";
page += amperreading;
page += " A</p>";
page += "</div>";
page += "<h3 class='text-primary'>Accum Consumption</h3>";
page += kwhaccumString;
page += " kWh (total)</p>";
page += "</div>";
page += "</div>";
page += "<h4 class='text-primary'>Frequency</h3>";
page += frequencystring;
page += " Hz</p>";
page += "</div>";
page += "<h4 class='text-primary'>Voltage/Tension</h3>";
page += voltagestring;
page += " V</p>";
page += "</div>";
page += "<h4 class='text-primary'>Power Factor</h3>";
page += pfactorstring;
page += " </p>";
page += "</div>";
page += "<div class='alert alert-dismissable alert-danger'>";
page += "<h5>Warning!</h4>Sometimes the board does not restart correctly. If you can't get back to this page after one minute, you need to reset on the board directly on the fisical reset button. ";
page += "<button type='button' class='btn btn-warning btn-default'>RESET</button>";
page += "</div>";
page += "</div>";
page += "</div>";
page += "copyright <br/><br/>";
page += "</div>";
page += "</div>";
page += "</body>";
page += "</html>";
return page;
void handleRoot() {
digitalWrite(led, 1);
server.send ( 200, "text/html", getPage() );
digitalWrite(led, 0);
void handleNotFound(){
String message = "File Not Found\n\n";
message += "URI: ";
message += server.uri();
message += "\nMethod: ";
message += (server.method() == HTTP_GET)?"GET":"POST";
message += "\nArguments: ";
message += server.args();
message += "\n";
for (uint8_t i=0; i<server.args(); i++){
message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
server.send(404, "text/plain", message);
void setup() {
pinMode(BUILTIN_LED, OUTPUT); // Initialize the BUILTIN_LED pin as an output
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
Serial.begin(115200); //initialize serial
sdm.begin(); //initalize SDM220 communication baudrate
//----------- OTA
ArduinoOTA.setHostname(mqttClientName);
ArduinoOTA.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH) {
type = "sketch";
} else { // U_SPIFFS
type = "filesystem";
// NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
Serial.println("Start updating " + type);
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
delay(1000);
ESP.restart();
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
if (MDNS.begin("esp8266")) {
Serial.println("MDNS responder started");
server.on("/", handleRoot);
server.on("/inline", [](){
server.send(200, "text/plain", "this works as well");
server.onNotFound(handleNotFound);
server.begin();
Serial.println("HTTP server started");
void setup_wifi() {
delay(10);
// config static IP
Serial.print(F("Setting static ip to : "));
Serial.println(ip);
WiFi.config(ip, gateway, subnet, dns);
// We start by connecting to a WiFi network
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
Serial.println();
// Switch on the LED if an 1 was received as first character
if ((char)payload[0] == '1') {
digitalWrite(BUILTIN_LED, LOW); // Turn the LED on (Note that LOW is the voltage level
// but actually the LED is on; this is because
// it is acive low on the ESP-01)
} else {
digitalWrite(BUILTIN_LED, HIGH); // Turn the LED off by making the voltage HIGH
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("SDM120",mqtt_user,mqtt_password,"sdm120/status", 2, 0, "0")) {
Serial.println("connected");
// Once connected, publish an announcement...
client.publish("sdm120/status", "1");
// ... and resubscribe
client.subscribe("inTopic");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void loop() {
server.handleClient();
if (!client.connected()) {
reconnect();
client.loop();
//handle OTA
ArduinoOTA.handle();
long now = millis();
if (now - lastMsg > 2000) {
lastMsg = now;
delay(5000);
s = String(sdm.readVal(SDM220T_VOLTAGE));
if (s != "nan") {
s.toCharArray(charBuf, 50);
client.publish("sdm120/volt", charBuf);
Serial.print("Voltage: ");
Serial.print(s);
Serial.println(" V");
voltage = sdm.readVal(SDM220T_VOLTAGE);
delay(50);
s = String(sdm.readVal(SDM220T_CURRENT));
if (s != "nan") {
client.publish("sdm120/curr", charBuf);
Serial.print("Current: ");
Serial.print(s);
Serial.println(" A");
ampe = sdm.readVal(SDM220T_CURRENT);
delay(50);
s = String(sdm.readVal(SDM220T_POWER));
if (s != "nan") {
client.publish("sdm120/pow", charBuf);
Serial.print("Power: ");
Serial.print(s);
Serial.println(" W");
poww = sdm.readVal(SDM220T_POWER);
delay(50);
s = String(sdm.readVal(SDM220T_ACTIVE_APPARENT_POWER));
if (s != "nan") {
client.publish("sdm120/act_app_pow", charBuf);
Serial.print("Active apparent power: ");
Serial.print(s);
Serial.println(" VA");
delay(50);
s = String(sdm.readVal(SDM220T_REACTIVE_APPARENT_POWER));
if (s != "nan") {
client.publish("sdm120/react_app_pow", charBuf);
Serial.print(s);
Serial.println(" VAR");
delay(50);
s = String(sdm.readVal(SDM220T_POWER_FACTOR));
if (s != "nan") {
client.publish("sdm120/pow_factor", charBuf);
Serial.print("Power factor: ");
Serial.print(s);
Serial.println(" ");
pfactor = sdm.readVal(SDM220T_POWER_FACTOR);
delay(50);
s = String(sdm.readVal(SDM220T_PHASE_ANGLE));
if (s != "nan") {
client.publish("sdm120/phase_angle", charBuf);
Serial.print("Phase angle: ");
Serial.print(s);
Serial.println(" Degree");
delay(50);
s = String(sdm.readVal(SDM220T_FREQUENCY));
if (s != "nan") {
client.publish("sdm120/freq", charBuf);
Serial.print("Frequency: ");
Serial.print(s);
Serial.println(" Hz");
frequency = sdm.readVal(SDM220T_FREQUENCY);
delay(50);
s = String(sdm.readVal(SDM220T_TOTAL_ACTIVE_ENERGY));
if (s != "nan") {
client.publish("sdm120/tot_act_en", charBuf);
Serial.print("Total active energy: ");
Serial.print(s);
Serial.println(" Wh");
kwhaccum = sdm.readVal(SDM220T_TOTAL_ACTIVE_ENERGY);
delay(50);
s = String(sdm.readVal(SDM220T_TOTAL_REACTIVE_ENERGY));
if (s != "nan") {
client.publish("sdm120/tot_react_en", charBuf);
Serial.print("Total reactive energy: ");
Serial.print(s);
delay(50);
s = String(sdm.readVal(SDM220T_IMPORT_ACTIVE_ENERGY));
if (s != "nan") {
client.publish("sdm120/import_act_en", charBuf);
Serial.print("Import active energy: ");
Serial.print(s);
delay(50);
s = String(sdm.readVal(SDM220T_EXPORT_ACTIVE_ENERGY));
if (s != "nan") {
client.publish("sdm120/export_act_en", charBuf);
Serial.print("Export active energy: ");
Serial.print(s);
delay(50);
s = String(sdm.readVal(SDM220T_IMPORT_REACTIVE_ENERGY));
if (s != "nan") {
client.publish("sdm120/import_react_en", charBuf);
Serial.print("Import reactive energy: ");
Serial.print(s);
Serial.println(" VARh");
delay(50);
s = String(sdm.readVal(SDM220T_EXPORT_REACTIVE_ENERGY));
if (s != "nan") {
client.publish("sdm120/export_react_en", charBuf);
Serial.print("Export reactive energy: ");
Serial.print(s);
dtostrf(ampe, 5, 2, amperreading);
dtostrf(poww, 5, 2, powreading);
dtostrf(kwhaccum, 5, 2, kwhaccumString); // Convert Accum kWh to string
dtostrf(voltage, 5, 2, voltagestring);
dtostrf(frequency, 5, 2, frequencystring);
dtostrf(pfactor, 5, 2, pfactorstring);
yield();
Serial.println("----------------------------------------");
//wait a while before next loop
, é que percebo nada disto, hehe
