Como adicionar cartões no Lovelace (Desactualizado)
Download dos Cards
Lista de resources:
resources:
  - type: js
    url: /customcards/github/thomasloven/card-tools.js?track=true
  - type: module
    url: >-
      https://cdn.jsdelivr.net/gh/bramkragten/custom-ui@master/swipe-card/swipe-card.min.js
  - type: module
    url: >-
      https://cdn.jsdelivr.net/gh/bramkragten/custom-ui@master/weather-card/weather-card.min.js
  - type: js
    url: /customcards/cards/alarm_control_panel-card/alarm_control_panel-card.js
  - type: js
    url: /customcards/cards/auto-entities/auto-entities.js
  - type: js
    url: /customcards/cards/bignumber-card/bignumber-card.js
  - type: module
    url: /customcards/cards/button-card/button-card.js
  - type: module
    url: /customcards/cards/calendar-card/calendar-card.js
  - type: js
    url: /customcards/cards/card-modder/card-modder.js
  - type: js
    url: /customcards/cards/compact-custom-header/compact-custom-header.js
  - type: js
    url: /customcards/cards/dual-gauge-card/dual-gauge-card.js
  - type: js
    url: /customcards/cards/entity-attributes-card/entity-attributes-card.js
  - type: js
    url: /customcards/cards/fold-entity-row/fold-entity-row.js
  - type: js
    url: /customcards/cards/home-setter/home-setter.js
  - type: js
    url: /customcards/cards/krisinfo-card/krisinfo-card.js
  - type: js
    url: /customcards/cards/layout-card/layout-card.js
  - type: js
    url: /customcards/cards/light-card/light-card.js
  - type: module
    url: /customcards/cards/mini-graph-card/mini-graph-card-bundle.js
  - type: module
    url: /customcards/cards/mini-media-player/mini-media-player.js
  - type: js
    url: /customcards/cards/monster-card/monster-card.js
  - type: js
    url: /customcards/cards/plan-coordinates/plan-coordinates.js
  - type: js
    url: /customcards/cards/popup-card/popup-card.js
  - type: module
    url: /customcards/cards/secondaryinfo-entity-row/secondaryinfo-entity-row.js
  - type: js
    url: /customcards/cards/slider-entity-row/slider-entity-row.js
  - type: js
    url: /customcards/cards/slideshow-card/slideshow-card.js
  - type: js
    url: /customcards/cards/state-attribute-element/state-attribute-element.js
  - type: js
    url: /customcards/cards/state-element/state-element.js
  - type: js
    url: /customcards/cards/state-switch/state-switch.js
  - type: js
    url: /customcards/cards/text-element/text-element.js
  - type: js
    url: /customcards/cards/toogle-lock-entity-row/toggle-lock-entity-row.js
  - type: js
    url: /customcards/cards/tracker-card/tracker-card.js?track=true
  - type: module
    url: /customcards/cards/upcoming-media-card/upcoming-media-card.js
  - type: js
    url: /customcards/cards/useful-markdown-card/useful-markdown-card.js
  - type: js
    url: /customcards/cards/username-element/username-element.js
  - type: js
    url: /customcards/cards/vertical-stack-in-card/vertical-stack-in-card.js
  - type: js
    url: /customcards/cards/browser-commander/browser-commander.js
Exemplo do card Slider entity Row
type: entities
title: Nome que queres dar é opcional esta linha
show_header_toggle: false
  - type: custom:slider-entity-row
    entity: light.58458727dc4f225785fa
:warning: Nota que este tutorial pode sofrer algumas alterações a partir da data em que este tópico foi criado por favor caso tenhas alguma dúvida comenta.
Ou aparece nosso Canal do Discord para obteres um apoio mais rápido.
:pushpin: Nos resources só estão alguns cards, podes depois adicionar mais.
Site para onde encontrar as resources: Aqui e Aqui
Estou a fazer alguma coisa mal? copiei a pasta cards para o dentro da pasta www e inseri os resources tal como indicado no video mas deu erro ao criar o card de teste:
Obrigado pelo tutorial :slight_smile:
Faz Guardar, limpa a cache do browser e verifica se funciona.
Não limpei o cache mas fiz Shift+F5 (chrome) para recargar o separado sem cache e continua a não dar :frowning:
Aparece no nosso canal do discord
https://discord.gg/Mh9mTEA para que assim que possível se agendar um apoio remoto para ver o que se passa com isso.
Posso confirmar que ficou tudo resolvido com a tua intervenção remota. O problema estava mesmo na local onde tinha colocado a tag “custom_updater:” dentro do ficheiro configuration.yaml que não estava no sitio certo. Não fazia ideia que isso fazia diferença :(. Estamos sempre a aprender… Mais uma vez obrigado pela ajuda, abraço.
Mesmo problema comigo… podem ajudar-me quando possível? Obrigado desde já.
@glitch aparece no nosso canal do Discord, link no post acima. Para tentarmos resolver o problema.
Resolvido… mas deu luta. limpeza do .storage ajudou. Já tenho os cards a funcionar. Muito obrigado pela ajuda.
Como fez para resolver? Comigo não consegui.
Seguiste o tutorial? Limpas te no final a cache?
Sim, mas não funcionou.
Boa Noite
Alguem pode ne disser onde coloco o “custom_updater:” dentro do ficleiro configuration.yaml?
nao tem sitio especifico desde que esteja dentro do configuration.yaml e posto corretamente
Pedro, foi engano…
Rodolfo,
criei um novo dashborad e coloquei lá os resorces.
está-me a dar o erro :
o que estou a fazer mal ?
penso que já consegui.
tenho de deixar alguma configuração da vista. é isso ?
@RicardoT este tutorial está desactualizado, deverás instalar o HACS para posteriormente instalares os cards que queres.
