Este fim de semana criei um novo projeto para a campainha cá de casa, utilizando o seguinte:
Nodemcu
Campainha existente, apenas para utilização do botão de pressão
Coluna Sonos ( funciona tb com a gateway Xiaomi)
Telegram
Camera IP
Com base no código deste post:
https://community.home-assistant.io/t/mqtt-doorbell/15081/20
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
//WIFI
const char* wifi_ssid = "wifi";
const char* wifi_password = "wifi-password";
//MQTT
const char* mqtt_server = "mqtt server ip";
const char* mqtt_user = "mqtt username";
const char* mqtt_password = "mqtt password";
const char* clientID = "Doorbell";
//VARS
const char* doorbell_topic = "home/outdoors/doorbell";
const int doorbellPin = D3;
int doorbellState = 0;
WiFiClient espClient;
PubSubClient client(espClient);
void setup() {
Serial.begin(115200);
pinMode(doorbellPin, INPUT_PULLUP);
pinMode(LED_BUILTIN, OUTPUT); // Initialize the LED_BUILTIN pin as an output
setup_wifi();
client.setServer(mqtt_server, 1883);
void blink_now(){
digitalWrite(LED_BUILTIN, LOW);
delay(1000);
digitalWrite(LED_BUILTIN, HIGH);
delay(1000);
void setup_wifi() {
//Turn off Access Point
WiFi.mode(WIFI_STA);
delay(10);
// We start by connecting to a WiFi network
Serial.println();
Serial.print("Connecting to ");
Serial.println(wifi_ssid);
WiFi.begin(wifi_ssid, wifi_password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
blink_now();
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
blink_now();
// Attempt to connect
if (client.connect(clientID, mqtt_user, mqtt_password)) {
Serial.println("connected");
// Once connected, publish an announcement...
client.publish(doorbell_topic, "Doorbell connected to MQTT");
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
doorbellState = digitalRead(doorbellPin);
if ( doorbellState == LOW ) {
// Put your code here. e.g. connect, send, disconnect.
Serial.println("Doorbell is pressed!");
client.publish(doorbell_topic, "on", true);
blink_now();
delay( 5000 );
Tendo a parte essencial a funcionar, venho solicitar a vossa ajuda porque sempre reinicio o HA este começa por se inscrever no MQTT novamente, o que por sua vez aciona a automação de toque da campainha.
Tenho hassbian instalado num raspberry pi.
Penso que a solução passará por limpar o sinalizador de retenção para o tópico em questão com o comando:
$ mosquitto_pub -t your_topic -r -n
e depois devo corrigir na campainha para não definir o sinalizador de retenção quando a mensagem é enviada, mas nesta parte não sei como devo fazer, alguém me pode ajudar? Obrigado.
