@pedrocampos No host: é só o IP da camara… Não é para colocares a porta RTSP :554
Nesse ficheiro onde estás a adicionar a camara, só podes ter uma vez camera: e depois as várias camaras de seguida nesse ficheiro… Não é para colocar camera: sempre que se adiciona uma camera…
Tens que reiniciar o Home Assistant depois de gravares o ficheiro. Verifica antes se te dá algum erro de configuração.
Eu tenho essa camara e funciona sem problemas da forma que estou a descrever.
2020-04-23 10:03:36 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'Frente', but will retry later. Error: Cannot connect to host 192.168.xx.xx:8000 ssl:None [Connect call failed ('192.168.xx.xx', 8000)]
2020-04-23 10:03:36 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 30 seconds.
2020-04-23 10:03:39 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for shelly which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-04-23 10:04:10 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'Frente', but will retry later. Error: Cannot connect to host 192.168.xx.xx:8000 ssl:None [Connect call failed ('192.168.xx.xx', 8000)]
2020-04-23 10:04:10 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 60 seconds.
2020-04-23 10:05:14 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'Frente', but will retry later. Error: Cannot connect to host 192.168.xx.xx:8000 ssl:None [Connect call failed ('192.168.xx.xx', 8000)]
2020-04-23 10:05:14 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 90 seconds.
2020-04-23 10:06:48 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'Frente', but will retry later. Error: Cannot connect to host 192.168.xx.xx:8000 ssl:None [Connect call failed ('192.168.xx.xx', 8000)]
2020-04-23 10:06:48 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 120 seconds.
2020-04-23 10:08:52 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'Frente', but will retry later. Error: Cannot connect to host 192.168.xx.xx:8000 ssl:None [Connect call failed ('192.168.xx.xx', 8000)]
2020-04-23 10:08:52 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 150 seconds.
2020-04-23 10:11:26 WARNING (MainThread) [homeassistant.components.onvif.camera] Couldn't connect to camera 'Frente', but will retry later. Error: Cannot connect to host 192.168.xx.xx:8000 ssl:None [Connect call failed ('192.168.xx.xx', 8000)]
2020-04-23 10:11:26 WARNING (MainThread) [homeassistant.components.camera] Platform onvif not ready yet. Retrying in 180 seconds.
e este
2020-04-23 17:24:09 ERROR (MainThread) [homeassistant.components.generic.camera] Error getting new camera image from Frente: Cannot connect to host 192.168.1.XXX:80 ssl:None [Connect call failed ('192.168.1.XXX', 80)]
@pedrocampos Coloca aqui o código yaml que estás a utilizar devidamente formatado.
Tens a certeza que estás a utilizar o IP correto da câmara?
Se colocares esse IP no browser consegues aceder às configurações da câmara?
Quando colocas aqui código com IPs internos da rede, como os 192.168.xxx.xxx não precisas estar a ocultar nada… Todos nós temos IPs desses ou parecidos na nossa rede e casa. O eu saber o IP interno que a tua câmara está a utilizar não vai fazer com que consiga aceder a ela a partir do exterior da tua rede.
tenho isto no meu config, tentei usar todas as opções que encontrei…
instalei um programa no PC chamado iSpy por esses links rstp consigo entrar e pelo motion eye tambem da unresponsive host.
