Camara Cell PT 2C ONVIF
Alguem ja conseguiu colocar esta camara no HA via ONVIF? so consigo via IMOU app mas tem aqueles limites e nao da para quase nada!
Nao consigo via onvif/webRTC ou simple cam!!!
Obrigado pelas respostas desde ja
Tente usar assim pelo webRTC.
Coloca senha e ip da camera, testa pra ver se vai. Tenho uma dahua/imou, consigo usar pelo onvif e pelo rtsp
rtsp://admin:senha@192.168.1.200:554/cam/realmonitor?channel=1&subtype=0
mas é a Cell 2PT?
nepias nao abre nada, ate da erro no vlc
The Imou Cell PT 2C (3MP/2K) is a battery-operated, solar-capable pan-and-tilt Wi-Fi security camera. It supports ONVIF and RTSP, allowing integration into third-party software like iSpy or NAS systems, although it is designed primarily for use with the Imou Life app, requiring a 2.4GHz Wi-Fi connection.
RTSP Setup and Details for Imou Cell PT 2C
  • Protocol: Supports Standard RTSP and ONVIF for streaming to NAS, NVR, or software like Blue Iris.
  • Default Credentials: The username is generally admin , and the password is the safety code found on the device label.
  • RTSP URL Structure: The general format for Imou cameras is:
    • Main Stream (High Quality): rtsp://admin:SafeCode@IP_ADDRESS:554/cam/realmonitor?channel=1&subtype=0
    • Sub Stream (Lower Quality): rtsp://admin:SafeCode@IP_ADDRESS:554/cam/realmonitor?channel=1&subtype=1
hello, sorry late responso but i’ve been busy…
i try this in vlc and no sucess… with pass, with code, no luck
