Broadlink - Usar Universal Remote APP para obter IR Codes no HASS
Descobri como retirar os codigos configurados na app Broadlink Universal Remote Android para usar no HASS.
Aqui vão os passos:
  • Instalar a app broadlink universal control
  • Adicionar device
  • Procurar community based Vodafone TV e testar ate um funcionar
  • Salvar dispositivo na conta e fechar app
  • Usar um file explorer e ir a /Android/data/cn.com.broadlink.econtrol*/cache/let/ircode/
  • Encontrará um ficheiro json com o seguinte formato:
{"status":0,"irDataList":[{"code":"2600bc000a07050b041b0609040b040b040b040b040b040b041604110416040b040b041b040a08000b920e09040b041c050904060a0a040a040b040b040b0416041104160607070a041b050a04000b940e09040b041b050a040a040b0708040b040b040b0416041004160509040b041b060904000b940e09040b051a050a040a040a050b040b040b040b0416050f0416040a0609041b060706000c2f0a090509041c0507070a040b0508071804160515050f0515040a040b041b060904000d05","function":"power","extend":"","type":0,"name":"开关","orderIndex":0},{"code":"2600b40008050a09041b050a0707050a0607070a040b0523050f0614041005100514060904000b900e07070a041c05090717050a040a040b040a0813050f0515050f050f0515050a04000b940a09040b051a050a040a0618040b040b040a0615050f0515050f04100614050a04000b900d09040b041b0609040b040b040b040b040b040a0416050f0614060e04110514060904000c260e09040b051a050a040b0618040b040b04160515050f0515050f0410051505000d05","function":"up","extend":"","type":0,"name":"上","orderIndex":0},{"code":"2600ba00090804070a1a0509040b040a0708040b040b040b0416060f0416060f050f0515050f05000b890e09040b041b06090408080a040b040b040b04080715051005140510050f0416050f05000b890e0906280609040b0509040b040b040b040a0416050f04160510050f0514060f05000b890e09040b041b0609040b040b040b040b040b040a041604110514060f050f0416050f05000c230a09040b051a050a040b0518040b040b04160614050f0416060e060f0415060f05000d05","function":"down","extend":"","type":0,"name":"下","orderIndex":0},{"code":"260090000909040b041b0618040a050a040b040b040b0416050f0614050f060f0415061406000b840d09040b041b0618040b0518040b040a0614060e04160510050f0515051406000b840d09040b051a050a040b0509040b040b040b040b0416050f0614050f060f0416061405000c1b0e09040a061a0518040b040b040a040b04160515050f0515050f050f0515051505000d05","function":"left","extend":"","type":0,"name":"左","orderIndex":0},{"code":"260070000909040b051a0609040b040a040b050a040a05090714050f0614050f04110514061a05000b7f0c0a040b051a050a040b040b040b040b040b040b0515050f0515050f060f0514061a05000c190909040a061a0518040b040b040a040b04160515050f0515050f04100515051a06000d05","function":"right","extend":"","type":0,"name":"右","orderIndex":0},{"code":"2600be00080a040b041c0509040b040b040b040b040b040b04150411051504110410041b060904000b8e0a090708041b0609040b040b040b040b040b040b04160411041604110411041b050a04000b8a1007040b041c0509040b050a040b040c040b040b0416060f041604110410041b060904000b8d0a0a040b041c0609040b040b040b040a040b040b0416050f0416050f050f041c050904000b8a0e090409071a0607070a040b0708040b040b04160614041105140410060f041c050a04000d05","function":"ok","extend":"","type":0,"name":"ok","orderIndex":0},{"code":"260058000001209312131113143611141212131212131113123812371213113912371139113812381113133712131114121311131114111312381312113811391437163211381138130005310001274b12000c5d0001254a13000d05","function":"volume_up","extend":"","type":0,"name":"音量+","orderIndex":0},{"code":"260058000001209213121213113813121213121311141113123812371114113812381138133712371238123713121114121311131213121312131212123811381238123812371139110005340001254b13000c5f0001234a14000d05","function":"volume_down","extend":"","type":0,"name":"音量-","orderIndex":0},{"code":"260098000809040b041b0508070a040b0708050a040a040b0713050f0416050f050f0510050708000b940d070706091a050a050a04080809040b040b040b041604100416041004100411050904000b960d09040b041b050a040b040b0708050a040a040b0515050f0416050f0410060f050906000c2c0a09040a051b050a040a0609040b050a040a05150515050f0416050f050f0411050904000d05","function":"menu","extend":"","type":0,"name":"菜单","orderIndex":0},{"code":"26009600080a040b041b0518040b040b040b040b040b04160410041605150509040b041b06000b890c0a040b041b050a040b040a040b040b040b040b0416050f041605150509040b041c05000b890c0a040b041b040b040b040b040b040b040b040b0416050f041605150509040b041b06000c1d0d09040b041b07080708040a040b040b040b04160614041004160515050a040a071905000d05","function":"back","extend":"","type":0,"name":"返回","orderIndex":0},{"code":"260058000001209311131213123811131213121311141113123811381213123811381238113812381237121311141137121411141113121311141138123811141138113911391039110005340001254b12000c5c0001264b12000d05","function":"mute","extend":"","type":0,"name":"静音","orderIndex":0}],"irInfo":{"cityid":"","providerid":"","irServeVersion":"","brandid":"","irId":194319,"countryId":"","provinceId":"","matchTreeVersion":"","irsource":"UserShared"}}
Cumprimentos,
HP
Ou para obter os códigos de cada aparelho podemos usar o programa “Broadlink Manager”. A documentação no site do Home Assistant recomenda:
Link: https://sourceforge.net/projects/broadlink-manager/
1- Instale o Broadlink Manager a partir deste link acima.
2- Abra o aplicativo e clique em “scan” para ativar seu dispositivo de broadlink.
3- Clique em “Learn New Command”, seu Broadlink vai piscar a luz para aprender novo comando. Então use o controle infra-vermelho. Vai aparecer no Broadlink Manager o código.
4- O “OnRawData Base64” é o código a ser usado com o Home Assistant.
A vantagem da minha solução é que consegue ter acesso ao user library do broadlink.
