Ajuda com AdGuard Home
Olá amigos,
Instalei o AdGuard Home pelo Supervisor e parece que está funcionando, mas quando coloco o IP do HA como DNS, as páginas de internet não carregam.
Configuration:
ssl: true
certfile: fullchain.pem
keyfile: privkey.pem
DNS Server Port: 530
(quando usava a 53 dizia que já estava em uso)
Log:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: AdGuard Home
 Network-wide ads & trackers blocking DNS server
 Add-on version: 2.4.1
 You are running the latest version of this add-on.
 System: Ubuntu 16.04.6 LTS  (aarch64 / qemuarm-64)
 Home Assistant Core: 0.111.4
 Home Assistant Supervisor: 227
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] adguard.sh: executing...
[cont-init.d] adguard.sh: exited 0.
[cont-init.d] discovery.sh: executing...
[19:57:07] INFO: Successfully send discovery information to Home Assistant.
[cont-init.d] discovery.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[19:57:13] INFO: Starting AdGuard Home server...
2020/06/22 19:57:13 [info] AdGuard Home, version v0.102.0, channel release, arch linux arm64 v6
2020/06/22 19:57:13 [info] Initializing auth module: /data/adguard/data/sessions.db
2020/06/22 19:57:13 [info] Auth: initialized.  users:0  sessions:0
2020/06/22 19:57:13 [info] Initialize web module
2020/06/22 19:57:13 [info] Bootstrap 0: 1.1.1.1:53
2020/06/22 19:57:13 [info] Upstream 0: https://dns10.quad9.net:443/dns-query
2020/06/22 19:57:13 [info] Go to http://127.0.0.1:45158
[19:57:13] INFO: Starting NGinx...
nginx: [alert] detected a LuaJIT version which is not OpenResty's; many optimizations will be disabled and performance will be compromised (see https://github.com/openresty/luajit2 for OpenResty's LuaJIT or, even better, consider using the OpenResty releases from https://openresty.org/en/download.html)
2020/06/22 19:57:14 [info] Starting the DNS proxy server
2020/06/22 19:57:14 [info] Ratelimit is enabled and set to 20 rps
2020/06/22 19:57:14 [info] The server is configured to refuse ANY requests
2020/06/22 19:57:14 [info] DNS cache is enabled
2020/06/22 19:57:14 [info] Creating the UDP server socket
2020/06/22 19:57:14 [info] Listening to udp://[::]:530
2020/06/22 19:57:14 [info] Creating the TCP server socket
2020/06/22 19:57:14 [info] Listening to tcp://[::]:530
2020/06/22 19:57:14 [info] Entering the tcp listener loop on [::]:530
2020/06/22 19:57:14 [info] Entering the UDP listener loop on [::]:530
Ao usar o IP, as páginas não carregam. Nenhuma.
